04-24-2016, 08:40 AM
I've noticed on other models (and simulators) there are flag configurations that would effectively amount to 'Continue On Error'. For the hp42s, this would refer to flag 25 (User's Guide pg 275).
Although there are 'Halt on Overflow' flags in the 35s (flags 5,6 page 14-9), they only seem to control overflow and don't seem to have a 'Continue on Error' setting. This makes it very difficult to trap for errors in your programs. My only workaround is a Kludge.
Say for example you have to take a square-root, and you know it will only work on reals, not vectors or complex numbers. Since there doesn't appear to be a CPLX? or VECT? instruction, you have to produce some way to trap these errors. Best I can come up with is to make programs Restartable with user flags. Here's an example:
When you run this with a real in STKX, then everything goes fine. But if you run it with a VECT or IMAG in STKX, then you will see an INVALID DATA message, as well as a FLAG_0 annunciator. If you then rerun PRGM_T then it will restart realizing FLAG_0 was never cleared, so an error must have occurred at T005
Since the flag annunciators are visible this at least lets the user know that something happened, and they should do something (like rerun the PRGM).
This is the best I can come up with to trap for errors in my programs.
Anyone have a better way for the 35s?
T001 LBL T ;Main Routine
T002 FS? 0 ;Check to see if we have been restared
T003 GTO T007 ;.. if so, go to Flag_0 restart point
T004 SF 0 ;Enter danger zone
T005 SQRT(X) ; dangerous operation
T006 CF 0 ;Leave danger zone
T007 FS? 0 ;Flag_0 Restart point
T008 XEQ T011 ;If flag was set, we must have restarted
T009 42 ;All code gets here, even errors
T010 RTN ;Return the answer to everything.
; Error Trap Code
T011 SF 10 ;Prepare to display msg
T013 FOUND BUG ;Display message
T014 PSE ;.. temporarily
T015 CF 10 ;Unset our flags
T016 CF 0 ;.. all of them
T017 RTN ;Done with trap, continue prog
