Full Version: TestLaTex
\[20*\log _{ 10 }{ (\frac { V }{ { V }_{ ref } } ) }\]
(04-18-2016 01:42 PM)Tugdual Wrote: [ -> ]\[20*\log _{ 10 }{ (\frac { V }{ { V }_{ ref } } ) }\]
How many \( dB \) are you getting from that pre-amplifier?
Smile
Who knew Tesla did typesetting?
Well, I did struggle with LaText. Before it used to be $$ and now it seems to be backslash and squared brackets. Is there a help showing these markups? The forum help doesn't mention anything.
(04-19-2016 07:08 AM)Tugdual Wrote: [ -> ]Well, I did struggle with LaText. Before it used to be $$ and now it seems to be backslash and squared brackets. Is there a help showing these markups? The forum help doesn't mention anything.
If you looks back in this Test forum you'll find a link to this document that explains how LaTex is implemented in MathJax which is what MyBB uses (which, of course, is the forum software we're using here).
(04-19-2016 10:03 AM)Katie Wasserman Wrote: [ -> ]
Thank you very much Katie. I can't believe I did get support from a test forum Smile Great moderation here!
First, thanks for the link, it confirms that it was what I found. Second, astounding link you have there in the signature! What a work!
I was also curious about the integration and it is as I thought, a very smart integration with a js library.
Does anyone have a link to this document? The link Katie posted is broken (understandably so).
I am trying to figure out how to get taller integral signs.
\( \dfrac{4}{3} \pi r^{3} - 2ab \sqrt{r^{2}- \left ( \dfrac{a}{2} \right ) ^2 - \left ( \dfrac{b}{2} \right ) ^2} - 8 \int_{\sqrt{r^{2} - \left ( \dfrac{a}{2} \right ) ^2 - \left ( \tfrac{b}{2} \right ) ^2}}^{r} \;\; \int_{0}^{\sqrt{r^2-y^2}} \sqrt{r^2-y^2-x^2} \;\; \mathrm{d}x \;\; \mathrm{d}y \)
Use \tfrac instead of \dfrac in the \sqrt of the lower limit:
\( \dfrac{4}{3} \times \pi \times r^{3} - 2ab \sqrt{r^{2}- \left ( \dfrac{a}{2} \right ) ^2 - \left ( \dfrac{b}{2} \right ) ^2} - 8 \int_{\sqrt{r^{2} - \left ( \tfrac{a}{2} \right ) ^2 - \left ( \tfrac{b}{2} \right ) ^2}}^{r} \;\; \int_{0}^{\sqrt{r^2-y^2}} \sqrt{r^2-y^2-x^2} \;\; \mathrm{d}x \;\; \mathrm{d}y \)
Use [] instead of ():
\[ \dfrac{4}{3} \times \pi \times r^{3} - 2ab \sqrt{r^{2}- \left ( \dfrac{a}{2} \right ) ^2 - \left ( \dfrac{b}{2} \right ) ^2} - 8 \int_{\sqrt{r^{2} - \left ( \tfrac{a}{2} \right ) ^2 - \left ( \tfrac{b}{2} \right ) ^2}}^{r} \;\; \int_{0}^{\sqrt{r^2-y^2}} \sqrt{r^2-y^2-x^2} \;\; \mathrm{d}x \;\; \mathrm{d}y \]
Or then set \displaystyle explicitly:
\(\displaystyle \dfrac{4}{3} \times \pi \times r^{3} - 2ab \sqrt{r^{2}- \left ( \dfrac{a}{2} \right ) ^2 - \left ( \dfrac{b}{2} \right ) ^2} - 8 \int_{\sqrt{r^{2} - \left ( \tfrac{a}{2} \right ) ^2 - \left ( \tfrac{b}{2} \right ) ^2}}^{r} \;\; \int_{0}^{\sqrt{r^2-y^2}} \sqrt{r^2-y^2-x^2} \;\; \mathrm{d}x \;\; \mathrm{d}y \)
Does this look better?
(11-04-2023 04:23 PM)DM48 Wrote: [ -> ]Does anyone have a link to this document?
TeX and LaTeX Support
Here's another alternative by embedding it as an SVG:
[Image: svg.image?\frac{4}{3}\times\pi\times&...mathrm{d}y]
You might want to use "\left" and "\right" to make those parentheses look right :
\[20*\log _{ 10 }{ \left (\frac { V }{ { V }_{ ref } } \right ) }\]
Jonathan
