// Opcode map source: wp34s.op (local directory)
// Opcode SVN version: -- unknown --
// wp34s_asm.exe: Source file(s): wp34s.dat
0001 **LBL A
0002 ENTER[^]
0003 1
0004 +/-
0005 ACOS
0006 RCL[times] Y
0007 COS
0008 DEC X
0009 4
0010 /
0011 x[<->] Y
0012 2
0013 /
0014 RCL- Y
0015 RCL L
0016 x!
0017 x[<->] Y
0018 2[^x]
0019 [times]
0020 x[<->] Y
0021 # [pi]
0022 x[<->] Y
0023 y[^x]
0024 [times]
0025 RTN
0026 **LBL B
0027 RCL+ X
0028 DEC X
0029 DEC X
0030 STO+ Y
0031 x[<->] L
0032 XEQ C
0033 RTN
0034 **LBL C
0035 STO+ X
0036 RCL- Y
0037 +/-
0038 x[<->] Y
0039 XEQ 001
0040 x[<->] Y
0041 XEQ 001
0042 /
0043 RTN
0044 **LBL 001
0045 # 1/2
0046 x[<->] Y
0047 RCL[times] Y
0048 x!
0049 x[<->] Y
0050 RCL+ L
0051 2[^x]
0052 [times]
0053 # [pi]
0054 [sqrt]
0055 /
0056 RTN
0057 **LBL D
0058 ENTER[^]
0059 INC X
0060 # 002
0061 IDIV
0062 XEQ C
0063 RTN
0064 END
// 64 total instructions used.
// 64 total words used.
// 64 single word instructions.
// 0 double word instructions.
Program A: double factorial. This uses the formula used by
Wolfram Alpha:
\[x!!=2^{\frac{x}{2}-\frac{\cos \left ( \pi x \right )-1}{4}}\times \pi ^{\frac{\cos \left ( \pi x \right )-1}{4}}\times\left ( \frac{x}{2} \right )!\]
4 A --> 8
6 A --> 48
7.77 A --> 290.3223156096666
8.88 +/- A --> 0.01106808239125682
3.33 +/- A --> -1,065802995433050
5 +/- A --> 0.3333333333333334
Program B: rising double factorial.
9.8 ENTER 3 B --> 1595.832000000000 ; 9.8 * 11.8 * 13.8 = 1595.832
8.1 ENTER 4 B --> 13957.60410000001 ; 8.1 * 10.1 * 12.1 * 14.1 = 13957.6041
Program C: falling double factorial.
7.7 ENTER 2 C --> 43.88999999999996 ; 7.7 * 5.7 = 43.89
6.6 ENTER 3 C --> 78.93600000000006 ; 6.6 * 4.6 * 2.6 = 78.936
Program D: double factorial (integer arguments). This and programs B and C uses a more simple formula found at
Wikipedia.
5 +/- D --> 0.3333333333333334
3 +/- D --> -1
4 D --> 8.000000000000001
Nice
Functions I considered implementing natively at one point....
cos(pi x) can be replaced by (-1)^x which should save a few steps at the start and be faster and more accurate.
The "XEQ C RTN LBL C" sequence can be simplified to LBL C too I think. Likewise, the "XEQ C RTN" at the end can be replaced by GTO C
- Pauli
(02-12-2016 06:27 AM)Paul Dale Wrote: [ -> ]cos(pi x) can be replaced by (-1)^x which should save a few steps at the start and be faster and more accurate.
Let's not forget CNST, a handy command that IMHO is overlooked too often. CNST 86 is pi/2, and after rearranging the x!! formula to...
\(x!!=2^{\frac{x}{2}}\cdot\left(\frac{\pi}{2}\right)^{\frac{\cos \left ( \pi x \right )-1}{4}}\cdot \left(\frac{x}{2}\right)!\)
...the A program gets quite a bit shorter:
LBL A
CNST 86
RCL Y
(-1)^x
DEC X
#004
y^x
#1/2
RCLx Z
2^x
STOx Y
x<> L
x!
x
RTN
Dieter
CNST 86 isn't an officially supported command and cannot be entered from the keyboard...
Pauli
(02-12-2016 10:45 AM)Paul Dale Wrote: [ -> ]CNST 86 isn't an officially supported command and cannot be entered from the keyboard...
It may not be officially supported but it can be entered from the keyboard, CNST is in the P.FCN menu.
(02-12-2016 07:49 AM)Dieter Wrote: [ -> ] (02-12-2016 06:27 AM)Paul Dale Wrote: [ -> ]cos(pi x) can be replaced by (-1)^x which should save a few steps at the start and be faster and more accurate.
LBL A
CNST 86
RCL Y
(-1)^x
DEC X
#004
y^x
#1/2
RCLx Z
2^x
STOx Y
x<> L
x!
x
RTN
7/12th shorter, actually!
The following preverves the Y register, but I need two more steps:
LBL A
ENTER
ENTER
2^x
RCL L
x!
x<>y
(-1)^x
DEC X
4
CNST 86
x<>y
y^x
RTN
Ideally, both Y and Z stack registers should be saved. Thus I would not need the alternative definition in program 01. The implementation of the rising and falling factorials might be more interesting, but they are defined in terms of the ordinary factorial and would take just a few steps each.
Walter's Blue Book is worth looking at sometimes. If I only knew the whereabouts of mine... (hidden somewhere in the house).
Thank you all for the optimization suggestions, formula rearrangement and comments.
Gerson.
(02-12-2016 02:21 PM)Gerson W. Barbosa Wrote: [ -> ]The following preverves the Y register, but I need two more steps:
Simply replace the initial ENTER ENTER || with #1/2 RCLx Y and it's one step less again. ;-)
(02-12-2016 02:21 PM)Gerson W. Barbosa Wrote: [ -> ]Ideally, both Y and Z stack registers should be saved. Thus I would not need the alternative definition in program 01.
Hmmm... this sounds quite challenging. Which does not mean it couldn't be done. ;-)
Dieter
(02-12-2016 11:56 AM)Didier Lachieze Wrote: [ -> ]It may not be officially supported but it can be entered from the keyboard, CNST is in the P.FCN menu.
I'd forgotten about that one. A side effect for allow indirect constants -- I don't remember why we included them but do remember doing it.
The manual doesn't number the constants, instead the has user to count them. It also stops the documentation at the final user constant.
[edit: this is incorrect]
I'd assumed the various system constants after that are all subject to change if XROM needed modification.
Pauli
(02-12-2016 07:54 PM)Dieter Wrote: [ -> ] (02-12-2016 02:21 PM)Gerson W. Barbosa Wrote: [ -> ]The following preverves the Y register, but I need two more steps:
That's it! Thanks again!
(02-12-2016 07:54 PM)Dieter Wrote: [ -> ] (02-12-2016 02:21 PM)Gerson W. Barbosa Wrote: [ -> ]Ideally, both Y and Z stack registers should be saved. Thus I would not need the alternative definition in program 01.
Why not using register I? Its content would be changed in the next complex operation anyway. Or does this look like cheating? :-)
0001 **LBL A
0002 z[<->] I
0003 # 1/2
0004 RCL[times] Y
0005 2[^x]
0006 RCL L
0007 x!
0008 [times]
0009 x[<->] Y
0010 (-1)[^x]
0011 DEC X
0012 # 004
0013 /
0014 CNST 86
0015 x[<->] Y
0016 y[^x]
0017 [times]
0018 RCL I
0019 [<->] YZXX
0020 RTN
(02-12-2016 07:54 PM)Dieter Wrote: [ -> ]Hmmm... this sounds quite challenging. Which does not mean it couldn't be done. ;-)
There are instructions included in the 34S for doing this kind of thing easily:
LBL A
LocR 08
STOS .00
X<> .00
STO L
RCLS .00
RTN
Not as good as XROM's xIN/xOUT but this version will nest and you've got the input value in a register for easy access and LastX is handled correctly. Not bad for five steps.
- Pauli
This doesn't use CNST. Only one more step than Dieter's:
LBL A
(-1)^x
DEC X
# pi
# 1/2
STOx Z
STOx Z
STOx Y
RCLx L
2^x
RCL L
x!
x
x<> Z
y^x
x
RTN
Corrupts all the (4 level) stack, but I'm planning to put it in XROM, so that will not be a problem.
The following replaces my initial programs. Thank you all for your suggestions, your pointing out my obvious mistakes and for the wp34s instruction set refresh.
0001 **LBL B
0002 RCL+ X
0003 DEC X
0004 DEC X
0005 STO+ Y
0006 x[<->] L
0007 **LBL C
0008 STO+ X
0009 RCL- Y
0010 +/-
0011 x[<->] Y
0012 XEQ A
0013 x[<->] Y
0014 XEQ A
0015 /
0016 RTN
0017 **LBL A
0018 z[<->] I
0019 # 1/2
0020 RCL[times] Y
0021 2[^x]
0022 RCL L
0023 x!
0024 [times]
0025 x[<->] Y
0026 (-1)[^x]
0027 DEC X
0028 # 004
0029 /
0030 CNST 86
0031 x[<->] Y
0032 y[^x]
0033 [times]
0034 RCL I
0035 [<->] YZXX
0036 RTN
0037 END
Rising factorial:
LBL 01
x<>y
Gamma
X<>Y
RCL+ L
Gamma
x<>y
RTN
Falling factorial:
LBL 02
x<>y
x!
x<>y
RCL+ L
x!
RTN
(02-13-2016 12:57 AM)emece67 Wrote: [ -> ]Corrupts all the (4 level) stack, but I'm planning to put it in XROM, so that will not be a problem.
In XROM there is no reason to not use the pi/2 constant. The name is defined symbolically and if it gets renumbered, the assembler deals with it.
Pauli
(02-13-2016 04:46 AM)Paul Dale Wrote: [ -> ]In XROM there is no reason to not use the pi/2 constant. The name is defined symbolically and if it gets renumbered, the assembler deals with it.
Is there a reason why these useful constants were not included in the regular CONST catalog as #pi/2, #ln2, #ln10, #sqrt2pi etc.? Is it the limited space again?
Dieter
(02-13-2016 06:53 AM)Dieter Wrote: [ -> ]Is there a reason why these useful constants were not included in the regular CONST catalog as #pi/2, #ln2, #ln10, #sqrt2pi etc.? Is it the limited space again?
Ask Walter
Each exposed constant does consume extra bytes so space is an issue as always. I think it is twelve bytes extra (maybe a bit more) per exposed constant -- the question, as always, is when to stop. Remembering that: "pi 2 /" is three steps.
Some of the constants are also virtually useless for the user, although after digamma was dropped there aren't as many of these.
Pauli
Thanks for the tip. I've removed some predefined constants in my build, so I try to avoid the use of CNST. "Num [pi]/2" worked fine.
(02-13-2016 07:05 AM)Paul Dale Wrote: [ -> ]the question, as always, is when to stop. Remembering that: "pi 2 /" is three steps.
True – but this applies other constants as well. Some physical constants provided by the 34s are simply products or quotients of two others. Or consider cases like Φ
0 and K
j – the one is simply the reciprocal of the other, so at least one of them is not required. And what about #eE? A simple 1 e
x would be fine either, wouldn't it? Even without disturbing the stack like a manual [pi] 2 [/] would do.
OK, constants like ln 2 or lg e can be obtained with two program steps, and they don't even cause stack problems (well, except losing LastX). Others do, so I would trade several of the present physical constants for a simple pi/2, pi/4 or some others.
But you said that the assembler can handle several constants, I assume this applies to cases like ln 10 or sqrt(2 pi). Could you kindly provide a list of these?
Dieter
(02-13-2016 07:00 PM)Dieter Wrote: [ -> ]But you said that the assembler can handle several constants, I assume this applies to cases like ln 10 or sqrt(2 pi). Could you kindly provide a list of these?
The wp34s.op file can tell you. Here is an excerpt:
0x2000 cmd # 1/2
0x2001 cmd # a
0x2002 cmd # a[sub-0]
0x2002 alias-c # a0
0x2003 cmd # a[sub-m]
0x2003 alias-c # SM_luna
0x2004 cmd # a[terra]
0x2004 alias-c # SM_terra
0x2005 cmd # c
0x2006 cmd # c[sub-1]
0x2006 alias-c # C1
0x2007 cmd # c[sub-2]
0x2007 alias-c # C2
0x2008 cmd # e
0x2009 cmd # eE
0x200a cmd # F
0x200b cmd # F[alpha]
0x200b alias-c # F_alpha
0x200c cmd # F[delta]
0x200c alias-c # F_delta
0x200d cmd # g
0x200e cmd # G
0x200f cmd # G[sub-0]
0x200f alias-c # Go
0x2010 cmd # G[sub-c]
0x2010 alias-c # catalan
0x2011 cmd # g[sub-e]
0x2011 alias-c # Ge
0x2012 cmd # GM
0x2013 cmd # h
0x2014 cmd # [h-bar]
0x2014 alias-c # hon2PI
0x2015 cmd # k
0x2016 cmd # Kj
0x2017 cmd # l[sub-p]
0x2017 alias-c # PlanckL
0x2018 cmd # m[sub-e]
0x2018 alias-c # me
0x2019 cmd # M[sub-m]
0x2019 alias-c # M_luna
0x201a cmd # m[sub-n]
0x201a alias-c # mn
0x201b cmd # m[sub-p]
0x201b alias-c # mp
0x201c cmd # M[sub-p]
0x201c alias-c # PlanckM
0x201d cmd # m[sub-u]
0x201d alias-c # mu
0x201e cmd # m[sub-u]c[^2]
0x201e alias-c # muc2
0x201f cmd # m[sub-mu]
0x201f alias-c # mMu
0x2020 cmd # M[sol]
0x2020 alias-c # M_sol
0x2021 cmd # M[terra]
0x2021 alias-c # M_terra
0x2022 cmd # N[sub-A]
0x2022 alias-c # Na
0x2023 cmd # NaN
0x2024 cmd # p[sub-0]
0x2024 alias-c # atm
0x2025 cmd # q[sub-p]
0x2025 alias-c # PlanckQ
0x2026 cmd # R
0x2027 cmd # r[sub-e]
0x2027 alias-c # Re
0x2028 cmd # R[sub-k]
0x2028 alias-c # Rk
0x2029 cmd # R[sub-m]
0x2029 alias-c # R_luna
0x202a cmd # R[sub-infinity]
0x202a alias-c # Rinf
0x202b cmd # R[sol]
0x202b alias-c # R_sol
0x202c cmd # R[terra]
0x202c alias-c # R_terra
0x202d cmd # Sa
0x202e cmd # Sb
0x202f cmd # Se[^2]
0x202f alias-c # WGS_E2
0x2030 cmd # Se'[^2]
0x2030 alias-c # WGS_ES2
0x2031 cmd # Sf[^-1]
0x2031 alias-c # WGS_F
0x2032 cmd # T[sub-0]
0x2032 alias-c # t
0x2033 cmd # t[sub-p]
0x2033 alias-c # tp
0x2034 cmd # T[sub-p]
0x2034 alias-c # PlanckTh
0x2035 cmd # V[sub-m]
0x2035 alias-c # Vm
0x2036 cmd # Z[sub-0]
0x2036 alias-c # Zo
0x2037 cmd # [alpha]
0x2037 alias-c # alpha
0x2038 cmd # [gamma]EM
0x2038 alias-c # EULER
0x2039 cmd # [gamma][sub-p]
0x2039 alias-c # gamP
0x203a cmd # [epsilon][sub-0]
0x203a alias-c # eps0
0x203b cmd # [lambda][sub-c]
0x203b alias-c # lamC
0x203c cmd # [lambda][sub-c][sub-n]
0x203c alias-c # lamCn
0x203d cmd # [lambda][sub-c][sub-p]
0x203d alias-c # lamCp
0x203e cmd # [mu][sub-0]
0x203e alias-c # mu0
0x203f cmd # [mu][sub-B]
0x203f alias-c # muB
0x2040 cmd # [mu][sub-e]
0x2040 alias-c # muE
0x2041 cmd # [mu][sub-n]
0x2041 alias-c # mun
0x2042 cmd # [mu][sub-p]
0x2042 alias-c # muP
0x2043 cmd # [mu][sub-u]
0x2043 alias-c # mu_u
0x2044 cmd # [mu][sub-mu]
0x2044 alias-c # mumu
0x2045 cmd # [sigma][sub-B]
0x2045 alias-c # sigma
0x2046 cmd # [PHI]
0x2046 alias-c # PHI
0x2047 cmd # [PHI][sub-0]
0x2047 alias-c # phi0
0x2048 cmd # [omega]
0x2048 alias-c # WGS_OMEGA
0x2049 cmd # -[infinity]
0x2049 alias-c # NEGINF
0x204a cmd # [infinity]
0x204a alias-c # INF
0x204d cmd # 1/eH
0x204e cmd # 1/eL
0x204f cmd # 1/[sqrt]5
0x204f alias-c # RECIP_SQRT5
0x2050 cmd # 1/[sqrt][pi]
0x2050 alias-c # RECIP_SQRTPI
0x2051 cmd # Chi2
0x2052 cmd # L10[^-1]
0x2052 alias-c # RECIPLN10
0x2053 cmd # LN2
0x2054 cmd # LN2[^-1]
0x2054 alias-c # RECIPLN2
0x2055 cmd # [pi]
0x2055 alias-c PI
0x2056 cmd # [pi]/2
0x2056 alias-c # PIon2
0x2057 cmd # [sqrt]2[pi]
0x2057 alias-c # SQRT_2_PI
0x2058 cmd # [integral]RgB
0x2058 alias-c # INT_R_BOUNDS
(02-12-2016 10:33 PM)Paul Dale Wrote: [ -> ]The manual doesn't number the constants, instead the has user to count them. It also stops the documentation at the final user constant.
Walter corrected me, I was wrong here too. The manual does list the extra constants and it does number them.
Pauli
(02-13-2016 10:41 PM)Paul Dale Wrote: [ -> ] (02-12-2016 10:33 PM)Paul Dale Wrote: [ -> ]The manual doesn't number the constants, instead the has user to count them. It also stops the documentation at the final user constant.
Speaking of factorials and constants, I've found quite by chance a remarkable approximation to a Gamma-related constant (13 SD!). It's the positive real root of the polynomial equation x^28 + x^27 + x^26 + ... + x^4 + x^3 + x^2 - 130615 = 0. I think the wp34s solver can handle that, but it might be easier to check this on the hp 50g:
« [ 1 ] { 29 } RDM 1 CON 28 [ 0 -130615 ] REPL PROOT 6 GET C→R DROP
The four rising and falling factorials functions have been naively implemented. They might overflow when they shouldn't, like some comb and perm functions in some old calculators.
Thanks, Walter, for helping. I haven't found my copy of the Blue Book yet, but at least I've found my spare wp34s with good batteries in it :-)
Gerson.
