Full Version: HP41 FI data line
Should the FI data line go high or low to indicate data available? FI line from the I/O ports?
Thanks,
Nate
Hi Nate,
In short, no, FI is the Flag Input line.
I'll add that this is the obscurest and most poorly documented line from the I/O interface. :-)
It's used only by peripherals (PRINTER, HP-IL, WAND, etc) when requesting service from the CPU and is held high for a full digit time (four clock bit time cycles). The exact digit when the FI line is high informs the CPU of the type of service/periphera requesting service.
To the best of my knowledge, apart from said peripherals, only the CL CPU (for obvious reasons) and the USB-41 (to simulate 82143A printer) handle this line. It has no use on ROM pacs or any other module.
Cheers from Canary Islands.
Diego.
