When trying to evaluate incomplete beta (ICBT) on the two versions of SandMath I'm using (SM9F and SM9G), the calculator just displays "RUNNING..." for a long time and never converges on an answer. ICBT is a FOCAL program, so I decided to have a look at it. It has an inauspicious beginning...
01 ST* 01
02 STO 00
03 STO 00
...and continues on for some 66 lines, eventually attempting to find the answer via the generalized hypergeometric function, HGF+. I tried calculating incomplete beta manually using SandMath's HGF+ function, and I get the right answer, with HGF+ converging reasonably quickly.
I don't have room in my NoV64 for the 32K monster that the latest SandMath has become, so I was wondering if someone with a 41CL could see if the function has been fixed. You can use the example from the manual:
PI
1
E^X
0.7
XEQ “ICBT“
->0.029623046
Thanks.
(01-16-2016 07:25 PM)quantalume Wrote: [ -> ]I don't have room in my NoV64 for the 32K monster that the latest SandMath has become, so I was wondering if someone with a 41CL could see if the function has been fixed. You can use the example from the manual:
PI
1
E^X
0.7
XEQ “ICBT“
->0.029623046
Thanks.
Works for me ;-? I just sent you the latest MOD files, you may have a version mismatch somewhere...?
(01-16-2016 07:47 PM)Ángel Martin Wrote: [ -> ]Works for me ;-? I just sent you the latest MOD files, you may have a version mismatch somewhere...?
OK, it looks like it was fixed somewhere between versions 9G and 9L. Since I'd like to continue to use the earlier 8K versions, what would be the easiest way to patch the ROM images? Here is, for example what the function looks like in version 9G:
_XR_002.19 B028 00B 050 .FATFUN ICBT BB50 ; MCode XROM 00.19 "ICBT"
BB4F 009 003 002 .FNAME "ICBT" ; 009 003 002 094
ICBT BB50 1B9 100 ?NC XQ 406E
BB52 130 175 LDI 175
BB54 132 A=A+B P-Q
LB_BB55 BB55 171 192 ?NC GO 645C
BB57 002 A=0 @R
BB58 133 JNC +26 LB_BB7E BB7E
BB59 134 UNDEF134
LB_BB5A BB5A 174 UNDEF174
BB5B 171 153 ?C GO 545C
BB5D 11B JNC +23 LB_BB80 BB80
BB5E 131 192 ?NC GO 644C
LB_BB60 BB60 003 JNC +00 LB_BB60 BB60
BB61 1A0 A=B=C=0
BB62 0FD 174 ?NC XQ 5D3F
LB_BB64 BB64 153 JNC +2A LB_BB8E BB8E
BB65 142 A=A+C @R
BB66 124 SELPF 4 ; Peripheral 4: HP-IL
BB67 143 JNC +28 LB_BB8F BB8F
BB68 134 UNDEF134
BB69 120 ?P=Q
BB6A 1E0 GOTOADR
LB_BB6B BB6B 007 JC +00 LB_BB6B BB6B
BB6C 080 UNDEF080
BB6D 124 SELPF 4 ; Peripheral 4: HP-IL
BB6E 142 A=A+C @R
BB6F 17F JC +2F LB_BB9E BB9E
LB_BB70 BB70 185 101 ?C XQ 4061
BB72 11B JNC +23 LB_BB95 BB95
BB73 171 166 ?NC GO 595C
BB75 1B6 A=A-1 XS
BB76 087 JC +10 LB_BB86 BB86
LB_BB77 BB77 171 112 ?NC GO 445C
BB79 1CE A=A-C ALL
BB7A 071 1A0 ?NC XQ 681C
BB7C 08D 185 ?C XQ 6123
LB_BB7E BB7E 106 A=C S&X
BB7F 130 177 LDI 177
BB81 123 JNC +24 LB_BBA5 BBA5
BB82 122 A=A+B @R
BB83 191 070 ?NC XQ MSGNO 1C64 ; HP41 SYSTEM ROM 1
BB85 141 132 ?NC GO 4C50
BB87 177 JC +2E LB_BBB5 BBB5
BB88 120 ?P=Q
BB89 11B JNC +23 LB_BBAC BBAC
BB8A 193 JNC +32 LB_BBBC BBBC
BB8B 000 NOP
BB8C 177 JC +2E LB_BBBA BBBA
BB8D 120 ?P=Q
LB_BB8E BB8E 143 JNC +28 LB_BBB6 BBB6
LB_BB8F BB8F 112 A=C P-Q
BB90 1CE A=A-C ALL
BB91 071 171 ?C XQ 5C1C
BB93 1A0 A=B=C=0
BB94 08D 174 ?NC XQ 5D23
BB96 132 A=A+B P-Q
BB97 177 JC +2E LB_BBC5 BBC5
BB98 120 ?P=Q
BB99 154 ?R= 6
BB9A 121 153 ?C GO 5448
BB9C 143 JNC +28 LB_BBC4 BBC4
BB9D 1CC UNDEF1CC
LB_BB9E BB9E 00B JNC +01 LB_BB9F BB9F
LB_BB9F BB9F 22F JC -3B LB_BB64 BB64
BBA0 000 NOP
BBA6 012 007 013 .FNAME "RGSORT" ; 012 007 013 00F 012 094
RGSORT BBA7 21D 122 ?NC GO 4887
You list this as a FOCAL function in the SandMath manual, but does it have some sort of MCODE launcher? How would I replace this with a straight FOCAL function? I think there is enough room without breaking the downstream addresses.
(01-17-2016 01:34 AM)quantalume Wrote: [ -> ]You list this as a FOCAL function in the SandMath manual, but does it have some sort of MCODE launcher? How would I replace this with a straight FOCAL function? I think there is enough room without breaking the downstream addresses.
This may not be as simple as it should, many versions have happened since and I have archived those older source files...
For a 'straight" FOCAL program I'd suggest you use JM Baillard's, which is the same I used in the SandMath. It is posted at the bottom of this page:
http://hp41programs.yolasite.com/gamma.php
(01-17-2016 07:56 AM)Ángel Martin Wrote: [ -> ]This may not be as simple as it should, many versions have happened since and I have archived those older source files...
Ok, perhaps the easiest thing to do is put a FOCAL program of the same name in user memory or HEPAX memory, which sits below the first ROM. This way it will find the replacement program first.
Do you ever break backwards compatibility with Library4 updates? For example, might I have a problem if I'm using an old SandMath44 with the latest Library4?
(01-17-2016 08:49 AM)quantalume Wrote: [ -> ] (01-17-2016 07:56 AM)Ángel Martin Wrote: [ -> ]This may not be as simple as it should, many versions have happened since and I have archived those older source files...
In very rare instances that may occur, but not likely. The Lib#4 code has been more or less frozen for a couple of years except a couple of tweaks for the 16C Emulator and the GJM Modules. . It's hard to say 100% since there are so many inter-dependencies.
