01-12-2016, 04:04 PM
Thanks to this thread I was able to get the diagnostic program onto my HP67E relatively quickly.
But in order to get it working I had to correct an error in the program (on the calculator) manually.
It seems that the key code parser in the ACT flash tool has "R->P" and (P->R) swapped.
"R->P" should be "32 72" and "P->R" should be "31 72", but it is the other way round.
The good news is, everything else works fine!
In case any one else wants to try, this is the code and as comment the original code from the and the post mentioned above and the keycodes:
LBL 0 ; LBL 0 31 25 00
CL REG ; CLRG 31 43
P<>S ; P<>S 31 42
CL REG ; CLRG 31 43
RTN ; RTN 35 22
LBL a ; LBL a 32 25 11
RND ; RND 31 24
RC I ; RCL I 35 34
X!=Y ; X!=Y? 32 61
R/S ; R/S 84
LBL 2 ; LBL 2 31 25 02
DSZ ; DSZ I 31 33
LBL 5 ; LBL 5 31 25 05
RC I ; RCL I 35 34
RTN ; RTN 35 22
LBL c ; LBL c 32 25 13
RCL (i) ; RCL (i) 34 24
RC I ; RCL I 35 34
X!=Y ; X!=Y? 32 61
R/S ; R/S 84
STO + 0 ; ST +0 33 61 00
DSZ ; DSZ I 31 33
GTO c ; GTO c 22 31 13
3 ; 3 03
EEX ; EEX 43
2 ; 2 02
RCL 0 ; RCL 0 34 00
X!=Y ; X!=Y? 32 61
R/S ; R/S 84
RTN ; RTN 35 22
LBL e ; LBL e 32 25 15
1 ; 1 01
- ; - 51
RTN ; RTN 35 22
LBL A ; LBL A 31 25 11
5 ; 5 05
7 ; 7 07
GSB 0 ; GSB 0 31 22 00
PAUSE ; PSE 35 72
GSB e ; GSB e 32 22 15
ENTER ; ENTER 41
RDOWN ; Rdn 35 53
X<>Y ; X<>Y 35 52
RUP ; Rup 35 54
RUP ; Rup 35 54
X<>Y ; X<>Y 35 52
RUP ; Rup 35 54
X!=0 ; X!=0? 31 61
X!=Y ; X!=Y? 32 61
RTN ; RTN 35 22
X>Y ; X>Y? 32 81
RTN ; RTN 35 22
X=Y ; X=Y? 32 51
RTN ; RTN 35 22
X<=Y ; X<=Y? 32 71
GTO 1 ; GTO 1 22 01
RTN ; RTN 35 22
LBL 1 ; LBL 1 31 25 01
ST I ; STO I 35 33
RC I ; RCL I 35 34
X<>Y ; X<>Y 35 52
X!=Y ; X!=Y? 32 61
RTN ; RTN 35 22
GSB 2 ; GSB 2 31 22 02
X!=0 ; X!=0? 31 61
GTO 3 ; GTO 3 22 03
RTN ; RTN 35 22
LBL 3 ; LBL 3 31 25 03
X=0 ; X=0? 31 51
RTN ; RTN 35 22
X<0 ; X<0? 31 71
RTN ; RTN 35 22
X>0 ; X>0? 31 81
GTO 4 ; GTO 4 22 04
RTN ; RTN 35 22
LBL 4 ; LBL 4 31 25 04
DSZ ; DSZ I 31 33
F? 2 ; F2? 35 71 02
GTO 5 ; GTO 5 22 05
DSZ ; DSZ I 31 33
F? 1 ; F1? 35 71 01
GTO 5 ; GTO 5 22 05
DSZ ; DSZ I 31 33
F? 3 ; F3? 35 71 03
GTO 6 ; GTO 6 22 06
GTO 5 ; GTO 5 22 05
LBL 6 ; LBL 6 31 25 06
DSZ ; DSZ I 31 33
F? 0 ; F0? 35 71 00
GTO 7 ; GTO 7 22 07
GTO 5 ; GTO 5 22 05
LBL 7 ; LBL 7 31 25 07
SF 2 ; SF2 35 51 02
SF 1 ; SF1 35 51 01
CF 0 ; CF0 35 61 00
DSZ ; DSZ I 31 33
F? 3 ; F3? 35 71 03
GTO 5 ; GTO 5 22 05
DSZ ; DSZ I 31 33
F? 0 ; F0? 35 71 00
GTO 5 ; GTO 5 22 05
DSZ ; DSZ I 31 33
F? 2 ; F2? 35 71 02
GTO 8 ; GTO 8 22 08
GTO 5 ; GTO 5 22 05
LBL 8 ; LBL 8 31 25 08
DSZ ; DSZ I 31 33
F? 1 ; F1? 35 71 01
GTO 9 ; GTO 9 22 09
GTO 5 ; GTO 5 22 05
LBL 9 ; LBL 9 31 25 09
DSZ ; DSZ I 31 33
F? 2 ; F2? 35 71 02
GTO 5 ; GTO 5 22 05
DSP 7 ; DSP 7 23 07
DEG ; DEG 35 41
SIN ; SIN 31 62
SIN-1 ; SIN^-1 32 62
GSB a ; GSB a 32 22 11
COS ; COS 31 63
COS-1 ; COS^-1 32 63
TAN ; TAN 31 64
TAN-1 ; TAN^-1 32 64
R->P ; ->P 32 72
P->R ; ->R 31 72
SIN ; SIN 31 62
H->H.MS ; ->HMS 32 74
H.MS->H ; HMS-> 31 74
LOG ; LOG 31 53
10^x ; 10^x 32 53
LN ; LN 31 52
e^x ; e^X 32 52
SQRT ; SQRT(X) 31 54
x^2 ; X^2 32 54
ENTER ; ENTER 41
Y^X ; Y^X 35 63
LastX ; Lastx 35 82
1/X ; 1/X 35 62
y^x ; Y^X 35 63
ENTER ; ENTER 41
+ ; + 61
LastX ; LastX 35 82
- ; - 51
ENTER ; ENTER 41
* ; * 71
LastX ; LastX 35 82
: ; / 81
FRAC ; FRC 32 83
LastX ; LastX 35 82
INT ; INT 31 83
+ ; + 61
x^2 ; X^2 32 54
D->R ; D->R 32 73
R->D ; R->D 31 73
EEX ; EEX 43
2 ; 2 02
X<>Y ; X<>Y 35 52
% ; % 31 82
DSP 1 ; DSP 1 23 01
LBL b ; LBL b 32 25 12
RC I ; RCL I 35 34
STO (i) ; STO (i) 33 24
DSZ ; DSZ I 31 33
GTO b ; GTO b 22 31 12
2 ; 2 02
4 ; 4 04
X<>I ; X<>I 35 24
GSB c ; GSB c 32 22 13
LBL d ; LBL d 32 25 14
DSZ ; DSZ I 31 33
RC I ; RCL I 35 34
ABS ; ABS 35 64
2 ; 2 02
4 ; 4 04
X!=Y ; X!=Y? 32 61
GTO d ; GTO d 22 31 14
ST I ; STO I 35 33
9 ; 9 09
EEX ; EEX 43
8 ; 8 08
7 ; 7 07
1/x ; 1/X 35 62
8 ; 8 08
CHS ; CHS 42
* ; * 71
SF 0 ; SF0 35 51 00
CF 1 ; CF1 35 61 01
SF 3 ; SF3 35 51 03
RAD ; RAD 35 42
DSP 3 ; DSP 3 23 03
ENG ; ENG 35 23
-x- ; PRT X 31 84
SCI ; SCI 32 23
-x- ; PRT X 31 84
DSP 1 ; DSP 1 23 01
FIX ; FIX 31 23
-x- ; PRT X 31 84
R/S ; R/S
