To make a backup of all my HP-41 modules I would like to get the "easiest way" to do that.
Layout:
HP-41 with plugged in module in port 1, USB interface to directly copy the complete Port 1 onto the computer and convert it into .mod......
Hardware: Meinderts MLDL, Diegos USB-41 (unfortuantelly Geirs "pc41" does not transfers entier modules), HP41CL (only serial, no USB), PIL-BOX of J.F.
Someone interested in writing the software? I would prefer the USB-41 because of the size and prize.
(01-09-2016 04:04 PM)Geir Isene Wrote: [ -> ]If you have a HP-41CL, then it's dead easy to export the module via pc41.
... and it'll be even easier to share those images with the community like we have always done, right?
It's a lot of work to do, guys
(01-09-2016 07:57 PM)HP-Collection Wrote: [ -> ]It's a lot of work to do, guys
Wow! 202 Modules, the best collection of 41 modules that I have seen.
If you do only 1 module a day, then by end of July they will all be done.
Best regards,
Sylvain
But haven't the majority of those already been done? That would make the task less daunting.
These are only the "no-boxed" ones
(01-10-2016 01:56 AM)HP-Collection Wrote: [ -> ]It's a lot of work to do, guys
Exactly because
most are already in the public domain you
only need to back up those that aren't, which (surprise, surprise) would be a much more manageable task - and wouldn't take you until July.
(01-15-2016 10:26 AM)Mike (Stgt) Wrote: [ -> ]I'd suggest to backup all and compare the results. There is always a chance (a little chance) to find a not yet known revision, even within those in public domain. And then it would be a realy collectors item.
That's what I'm thinking, too. I would be glad to have MY modules save as there are some EPROMs that might got damaged by UV (yes, I have new UV stickers on them).
