01-04-2016, 04:16 AM
I have just added a warning to the 41CL Flash Update document. While going through the update process on one of my machines I got distracted long enough that the PC went to sleep with the 41CL still connected. It appeared that the 41CL was locked up, so I disconnected the serial port and removed the batteries. But now the machine is unresponsive.
So, if you're updating the Flash, don't let this happen to you. I wouldn't connect a 41CL to an unpowered PC and then power up the PC either.
