01-01-2016, 10:56 PM
I've enhanced the classic Windows GUI application with new menu choices:
In addition, you can name the initial state file on the command line of wp34sgui.exe.
In order to use the text file import feature, edit wp34s.ini and add a line with the name of the assembler tool, e.g. ..\tools\wp34s_asm.pl (or .exe if you don't have Perl installed). The path may include spaces. The program file is compiled with the -pp switch set and the code is appended to program memory in RAM in the same way PRCL works. This way you can easily add any library program to the emulator. Be aware that this will add a new copy of the program with each import!
The export feature works without the tools. It exports the complete RAM if called while in program mode or, while in run mode, just the current program (which can be in the lib area).
- Reload State: Reload the current state file from disk in order to revert to the last saved state
- Load State...: Access a different state file and make it current
- Save State: Save the state to the current state file
- Save State as...: Save the state to a new state file and make it current
- Import Program...: Import a text (.wp34s) file with help of the assembler tool
- Export Program...: Create a text (.wp34s) file from the current program
