I came across this wiki with the HP 41 mainframe entry points:
http://mcode.wikia.com/wiki/Mainframe_entry_points
All of these entry points are in pages 0, 1 and 2. Are any of these exclusive to the CX, or are all of the CX entry points higher up, in pages 3 and 5? I'm interested in knowing where the code resides which is CX-specific but which can't be added to a C or CV with the Time and X functions modules. Would that be page 3?
Thanks,
Dave
(12-24-2015 01:52 AM)quantalume Wrote: [ -> ]I came across this wiki with the HP 41 mainframe entry points: http://mcode.wikia.com/wiki/Mainframe_entry_points
For the most part those entry points are common to the CX as well. There are some changes made to the CX OS to connect with pages #3 and #5 - this one has two banks to accommodate not only the time module but also additional X-Functions code not present in the XF/M modules.
So yes, as you suspected that's where the code is - which explains why the library#4 concept works on the CX since all the addresses have a fixed location and thus the system calls need not to worry about XFM module locations at all.
Cheers,
'AM
(12-28-2015 10:35 PM)Mike (Stgt) Wrote: [ -> ]Is there somewhere an entry point list for the Voyagers?
I tried to identify the code of the
HP-15C that is equal or similar to the
HP-41C and use the same identifiers as in VASM:
07341: MP2-10 0056 b=0 w
07343: MP1-10 0530 m=c
07345: MP2-13 0076 b=0 s
07354: MPY110 0016 a=0 w
07357: MPY120 1734 inc pt
07362: MPY130 0456 a=a+b w
07363: MPY140 1142 c=c-1 p
07370: MPY150 0256 ac ex w ***ROUND, SHIFT AND NORMALIZE
07372: MPY160 1376 ? c<>0 s
07376: SHF40 0256 ac ex w
07377: SHF10 1534 pt= 12
07402: NRM10 0356 bc ex w
07403: NRM11 0256 ac ex w
07404: NRM12 1534 pt= 12
07415: NRM30 0336 c=b s
07423: NRM40 1740 rtn
07424: NRM20 0306 c=b x
07431: NRM13 0156 ab ex w
07433: SHF20 1502 ? a<>0 p
07500: 1/X10 0056 b=0 w
07503: 1/X13 0116 c=0 w
07510: X/Y13 0356 bc ex w
07537: DV2-10 0056 b=0 w
07541: DV1-10 0530 m=c
07543: DV2-13 0076 b=0 s
07547: DIV100 0730 c<>m
07554: DIV110 0730 c<>m
07560: DIV15 1456 ? a<b w
07566: DIV120 1534 pt= 12
07571: DIV130 1042 c=c+1 p
07572: DIV140 0616 a=a-b w
07643: SQR10 0056 b=0 w ***SQUARE ROOT
07646: SQR13 0576 a=a+1 s
07650: ERR0 1634 pt= 0
07653: SQR20 0036 a=0 s
07676: SQR30 0756 c=c+c w
07704: SQR50 1616 a sr w
07713: SQR60 1042 c=c+1 p
07714: SQR70 0716 a=a-c w
07723: SQR100 1712 c sr wp
10036: STSCR 0116 c=0 w
10067: RCSCR 0116 c=0 w
10236: ADDONE 0116 c=0 w
10241: SUBONE 0116 c=0 w
10243: SUBON1 1534 pt= 12
10276: SB2-10 1276 c=-c-1 s
10277: AD2-10 0056 b=0 w
10301: AD1-10 0530 m=c
10303: AD2-13 0076 b=0 s
10307: ADD10 1724 dec pt
10323: ADD30 1446 ? a<b x
10325: ADD90 0730 c<>m
10332: ADD90 0730 c<>m
10340: ADD55 0730 c<>m
10344: ADD65 0636 a=a-b s
10347: ADD40 1216 c=-c w
10361: ADD50 1446 ? a<b x
10373: ADD60 0256 ac ex w
10560: LNSUB- 1276 c=-c-1 s
10561: LNSUB 0156 ab ex w
10564: LNSUB1 1616 a sr w
10572: LNSUB2 1046 c=c+1 x
10601: EXP10 0056 b=0 w ***EXP(X)
10604: EXP13 1204 s=0 7
10605: EXP13* 0404 s=0 8
10611: EXP110 0036 a=0 s
10623: EXP130 1724 dec pt
10631: EXP400 0335 ?nc call 11067 LNC20
10634: EXP200 0241 ?nc call 11050 LNC10
10640: EXP120 0156 ab ex w
10644: EXP210 1072 c=c+1 m
10645: EXP220 0616 a=a-b w
10662: EXP240 1534 pt= 12
10664: EXP230 0256 ac ex w
10671: EXP300 0116 c=0 w
10702: EXP700 0156 ab ex w
10704: EXP710 0114 ? s=0 4
10714: EXP720 1214 ? s=0 7
10720: EXP730 0145 ?nc goto 07431 NRM13
10722: EXP410 1042 c=c+1 p
10723: EXP420 0616 a=a-b w
10733: EXP430 0356 bc ex w
10736: EXP500 0356 bc ex w
10737: EXP510 0114 ? s=0 4
10745: EXP570 1334 pt= 13
10750: EXP550 1372 ? c<>0 m
10753: EXP560 1342 ? c<>0 p
10776: EXP600 0156 ab ex w
11013: EXP540 1656 b sr w
11014: EXP530 1176 c=c-1 s
11022: LNAP 0530 m=c
11031: LNAP1 1716 c sr w
11037: LNAP2 0546 a=a+1 x
11047: LNC10* 0356 bc ex w
11050: LNC10 1534 pt= 12
11067: LNC20 0116 c=0 w
11113: LNC30 0620 lc 6
11127: LNCEND 0356 bc ex w
11131: LNC40 0320 lc 3
11146: LNC50 0434 pt= 8
11161: LNC60 0534 pt= 6
11173: LNC70 0134 pt= 4
11202: LNC80 0460 ldi 1463
11206: XY^X 0056 b=0 w
11224: ERR0* 1241 ?nc goto 07650 ERR0
11226: YX12 1346 ? c<>0 x
11231: YX11 1756 a sl w
11246: YX13 0531 ?nc call 24526
11255: YXTEN 0056 b=0 w
11260: YX31 0510 s=1 6
11275: LN10 0056 b=0 w
11300: LN13 0504 s=0 6
11301: LN130 0404 s=0 8
11320: LN140 0016 a=0 w
11326: LN310 1042 c=c+1 p
11327: LN300 0216 b=a w
11332: LN220 1534 pt= 12
11341: LN200 1502 ? a<>0 p
11346: LN210 0730 c<>m
11352: LN1+X2 1171 ?nc call 10236 ADDONE
11372: LN1+X6 1534 pt= 12
11400: LN1+X3 0410 s=1 8
11402: LN1+X8 0524 ? pt= 6
11406: LN1+X7 1046 c=c+1 x
11411: LN320 1616 a sr w
11412: LN330 1176 c=c-1 s
11442: LN460 1616 a sr w
11443: LN430 0356 bc ex w
11444: LN431 0335 ?nc call 11067 LNC20
11461: LN500 0235 ?nc call 11047 LNC10*
11472: LN570 0034 pt= 3
11473: LN520 0611 ?nc call 11542 PMUL
11501: LN410 0356 bc ex w
11503: LN540 1616 a sr w
11505: LN530 1536 ? a<>0 s
11510: LN550 0136 c=0 s
11524: YTOX50 0630 c=m
11525: YTOX60 1376 ? c<>0 s
11541: PMUL1 0456 a=a+b w
11542: PMUL 1142 c=c-1 p
11605: ERRDE 1604 s=0 0
20064: CHK#S 0475 ?nc call 25517
But as you may imagine the list is far from complete.
HTH
