In CHOOSE, I can choose just one from an arbitrary list using:
ASTEROIDS:={"1", "2",..." n"};
CHOOSE(CHS,"",ASTEROIDS);
But what I want is to able to select more than one, so that I could select several for plotting.
INPUT allows multiple items to be selected from check boxes, but the help seems to assume you know how many check boxes you have, and each is associated with a variable.
Using a list variable with check boxes compiles, but gives a run time error:
EXPORT BS()
LOCAL UTPLST:={};
LOCAL OKC,UTP;
LOCAL TTL:={"//"};
LOCAL LBL:={"Select"};
LOCAL HLP:="HH";
LOCAL ASTEROIDS:={"ONE","TWO","THREE"};
OKC:=INPUT({{UTPLST,ASTEROIDS}},TTL,LBL,HLP,1,1);
MSGBOX(UTPLST);
OKC:=INPUT({{UTPLST(1),1},{UTPLST(2),1}},TTL,LBL,HLP,1,1);
EXPORT UN()
BS()
(If that code had worked, I would have gone on to replace 1,2 with I=1 to size(ASTEROIDS)...)
Is there a way to do this with a list?
The output could either be a list of the same size as ASTEROIDS, populated with true and false...
Or a smaller list containing just those which have been selected/unselected.
If this cannot be done, could the functionality be added, either to INPUT or CHOOSE?
I now have a syntax which generates the user interface I was aiming for...
but so far I am entering each list elements manually...
I'm hoping this can be simplified to simply use the whole list
EXPORT BS()
LOCAL LST:={};
LOCAL UTPLST:={'LST(1)','LST(2)','LST(3)','LST(4)'};
LOCAL OKC,UTP;
LOCAL TTL:={"//"};
//LOCAL LBL:={"Select"};
LOCAL HLP:="HH";
LOCAL COMETS:={"ALL","Halley","Lewkowicz","The rest"};
//MSGBOX(UTPLST);
OKC:=INPUT({{UTPLST(1),1},{UTPLST(2),1},{UTPLST(3),1},{UTPLST(4),1}},TTL(1),COMETS,HLP,1,1);
EXPORT UN()
BS()
So, what you are really looking for is a way to programaticaly create your variable list, both for storing the values AND for the INPUT command...
Why not try:
EXPORT BS()
LOCAL LST:=MAKELIST(0,I,1,SIZE(COMETS));
LOCAL OKC,UTP;
LOCAL TTL:={"//"};
LOCAL HLP:="HH";
local l2= MAKELIST({'LST(I)',1},I,1,SIZE(COMETS));
OKC:=EVAL(EXPR("INPUT("+STRING(l2)+",TTL(1),COMETS,HLP,1,1)"));
The INPUT command needs both the NAME of the variable and their values...
This is why INPUT does NOT evaluate its first parameter, if it did evaluate it, then it would NOT be able to get the variable name that it needs...
As a result, it is NOT possible to use a programmatic way/method to generate that first parameter, because recalling it, is an evaluation, which does not happen...
Hence the use of a string there to generate the TEXT of the INPUT statement and then the conversion from text to an expression, which is then evaluated...
Cyrille
(11-11-2015 06:42 AM)cyrille de brébisson Wrote: [ -> ]Hello,
Why not try:
EXPORT BS()
LOCAL OKC,UTP;
LOCAL TTL:={"//"};
LOCAL HLP:="HH";
Cyrille
That looks right, but there is something wrong with the MAKELIST...
It generates LST1...LST1... for some reason.
If that is manually changed to LST1...LST2... Then LST has the desired output.
EXPORT BS()
LOCAL OKC,UTP;
LOCAL TTL:={"//"};
LOCAL HLP:="HH";
local l2={{'LST(1)',1},{'LST(2)',1},{'LST(3)',1},{'LST(4)',1}};
MSGBOX(LST);
I don't understand why that 2nd MAKELIST didn't generate LST(1...LST(2
But since the INPUT turns list l2 into a string, that MAKELIST isn't needed: one can make the required string directly.
This code seems to achieve what I was looking for:
EXPORT BS()
LOCAL ST:="{";
LOCAL COMETS:={"ALL","Halley","Lewkowicz","lots more"};
LOCAL LST:=MAKELIST(0,I,1,SIZE(COMETS));//MAKE LIST FOR RESULTS
LOCAL OKC;
LOCAL TTL:="Select Some";
LOCAL HLP:="HH";
//MAKE STRING FOR INPUT
FOR I FROM 1 TO SIZE(COMETS) DO
ST:=ST+"{LST("+I+"),1}";
ST:=REPLACE(ST,"}{","},{");//COMMA SEPERATOR
ST:=ST+"}";
//MSGBOX(ST);
OKC:=EVAL(EXPR("INPUT("+ST+",TTL,COMETS,HLP,1,1)"));
IF OKC THEN
MSGBOX(LST);
ELSE
//INPUT CANCELLED
//MAY WANT TO EMPTY LST?
Many thanks for your help with the syntax.
Yes, indeed the 2nd MAKELIST does do something strange...
But yes, the workaround is, as you stated to make the string directly...
Cyrille
