10-31-2015, 11:44 PM
Goal
The goal of this procedure is to reset the FRAM71 or FRAM71B module to its initial configuration.
Background
The usage of Ferroelectric Random Access Memory by the FRAM71 or FRAM71B module is a blessing and a curse.
The blessing of the module, is that you can remove the module without loosing its content and configurations.
The curse of the module, is that you can remove the module without loosing its content and configurations.
While learning the huge possibilities of the module, I got lost many times and I had a lot of frustrations.
It took me quite some time to figure how to put back the FRAM71 or FRAM71B module to its initial state, so here it is ...
Revisions
- 2021-02-01 Upd: Formatting.
- 2021-01-30 Upd: Default jumpers configuration tables & minor comments updates.
- 2021-01-23 Upd: MEM approximated values has been modified to match observed values.
- 2021-01-14 Upd: Finally updated to support FRAM71B module.
- 2017-01-24 Add: Out of date warning (FRAM71B not supported).
- 2015-11-08 Add: "Disclaimer" & minor formatting adjustments.
- 2015-11-07 Add: "Revisions" & "Additional Informations" sections & minor adjustments.
- 2015-11-01 Add: acknowledgments
- 2015-10-31 Add: Initial release, corrected typo
I would like to thank ...
- Hans Brüggemann for making these fantastic modules.
- Dave Frederickson and Robert Prosperi for their invaluable help and their infinite patience.
This procedure was done in good faith.
I do not offer any warranty of any kind.
If you follow this procedure as written, it should work.
If not, send me a PM, or better, post a message in the forum and I will help you, within the limit of my knowledge of course.
Assumptions
- The following procedure assume the FRAM71 or FRAM71B module is plugged into the the card reader port.
- The following procedure also assume that no front port modules are present.
- The presence of the HP-IL interface is not affecting.
- FRAM71B (Hardware v1.5, Firmware v6.07, "Denver 2016")
- FRAM71 (Hardware v1.4, Firmware v5.11, "Nashville 2015")
FRAM71 Default jumpers configuration
Header Jumper Description
J2 Installed SysRAM Disabled
J1 Removed SysRAM Disabled
CN2-1 Removed Bottom 512KB FRAM Board Selected
CN2-2 Removed IRAM Mapping Enabled
CN2-3 Removed FRAM Mapping Enabled
CN2-4 Removed SysRAM Writing Disabled
CN2-5 Removed Chip #0 Mapping to E0000 Disabled
FRAM71B Default jumpers configuration
Disable IRAM Mapping
[OFF] → Powering off the computer
Add jumper to [CN2-2] → IRAM Mapping Disabled
[ON] → Powering on the computer
Map the second half of the FRAM memory
POKE "2C000","98999A9B9C9D9E9F00" [ENTER] → Map memory 8 * 32KB = 256KB
[OFF] then [ON] → Activate the new configuration
Erase FRAM contents
[ON]+[/] [3] [ENTER] → "Memory Lost" - erase mapped FRAM71 memory
[ON] → Remove message
MEM [ENTER] → Should display 279040 bytes or a value very near to that number (256KB+17.5KB)
Map the first half of the FRAM memory
POKE "2C000","909192939495969700" [ENTER] → Map memory 8 * 32KB = 256KB
Erase FRAM contents
[ON] → Remove the message
Enable IRAM Mapping
Remove jumper from [CN2-2] → IRAM Mapping Enabled
MEM [ENTER] → Should display 16936 bytes or a value very near to that number (17.5KB)
Validate FRAM71 first erasure
POKE "2C000","98999A9B9C9D9E9F00" [ENTER] → Map the second half of the FRAM memory
MEM [ENTER] → Should display 279006 bytes or a value very near to that number (256KB+17.5KB)
SHOW PORT [ENTER] → 1BBBB: should show no ports in the 5.XX range
→ 2CDCC: all ports with the 5.XX range should have the type 0 (RAM)
Validate FRAM71 second erasure
POKE "2C000","909192939495969700" [ENTER] → Map the first half of the FRAM memory
MEM [ENTER] → Should display 278962 bytes or a value very near to that number (256KB+17.5KB)
Unmap FRAM71 memory
POKE "2C000","00000000000000000000000000000000" [ENTER] → Remove FRAM71 memory from the memory map
MEM [ENTER] → Should display 16810 bytes or a value very near to that number (17.5KB)
The FRAM71 is now back to its initial configuration!
Two tricks I have used to simplify this procedure.
Trick #1
When the 71B goes through its initialization procedure, all memory modules are mapped according to their types, sizes, etc.
RAM modules starting with “B3DDDDDE” are considered as IRAM and as you known all IRAM modules are protected against INIT 3 (Memory Lost).
Fortunately, the FRAM71 and FRAM71B modules has a jumper (CN2-2) that has been created to go around this protection.
By closing the jumper, the FRAM71 or FRAM71B module make the 71B ignore the IRAM identifier, and the 71B add these IRAMs to the main RAM, thus make them erasable by INIT 3.
Trick #2
One of the FRAM71 rules is that: You shall never map the "F-Block #2" to a "Chip #"
The main reason is that portion of F-Block #2 (2C000 to 2C01F) is used to configure the FRAM71 or FRAM71B module itself and mapping this section to the main memory will make the 71B and the FRAM71 or FRAM71B module to misbehave.
If you look carefully, in the second erasure, I have broken that rule by mapping it ["9091(92)939495969700"] to main memory.
The mapping duration is very small because we map it, then we power cycle, then we reinitialize the memory (INIT 3) effectively clearing the configuration space (2C000 to 2C01F) of the FRAM71 at the same time.
That is why after we remove the CN2-2 jumper, instead of having 273.5KB of RAM we only have 17.5KB RAM.
Sylvain
