10-27-2015, 08:34 PM
A program to convert units for length, volume, time, or weight. After installing CNV click on the Toolbox, select the USER tab, and choose CNV. The calculator may be in Textbook or RPN modes. Under Textbook specify the input as a function parameter:
CNV(5)
With RPN enter the number, press ENTER, then invoke CNV:
5 ENTER CNV
You will be prompted to indicate whether the conversion is for Length, Volume, Time, or Weight. Then indicate the units you are converting from and to. If units are specified on input then you will only be prompted to enter output units and the results will include units. The program remembers your selections for input and output units for the next time.
CNV(1) --> 2.54
CNV(1_inch) --> 2.54_cm
CNV(5)
5 ENTER CNV
CNV(1) --> 2.54
#pragma mode(separator(.,;) integer(h32))
// when changing menus update the following: cFr, cTo, unit, prog
cFr = {1,1,1,1};
cTo = {1,1,1,1};
iPr;
EXPORT CNV(x)
begin
local unit = {
{"mm", "cm", "m", "km", "inch", "ft", "yd", "mile"},
{"ml", "l", "tsp", "tbsp", "cu", "qt", "ozfl", "inch^3", "ft^3"},
{"s", "min", "h", "d", "yr"},
{"g", "kg", "oz", "lb"}
local prog = {
"Length",
"Volume",
"Time",
"Weight"
local t = type(x);
local x0 = x;
local uFr, uTo, n;
if (t <> 0) and (t <> 9) then msgbox("Input must be REAL or UNIT"); return x0; end;
choose(iPr, "convert", prog);
if (iPr == 0) then return x0; end;
if (t == 0) then
n := cFr[iPr];
choose(n, "From", unit[iPr]);
if (n == 0) then return x0; end;
uFr := expr("1_" + unit[iPr,n]);
x := x * uFr;
cFr[iPr] := n;
end;
n := cTo[iPr];
choose(n, "To", unit[iPr]);
uTo := expr("1_" + unit[iPr,n]);
x := convert(x, uTo);
cTo[iPr] := n;
if (t == 0) then x := x / uTo; else x; end;
end;
