Full Version: HP35s Entering complex number arguments
I feel that I am missing something, but I am struggling to enter non-trivial arguments for complex numbers in RPN mode on the HP35s. For example, how would I enter something like "5 theta pi"? When I try it the obvious way, I get a syntax error. Or if I would like to do something like "2*2 + 4i"?
Is there a way to use the value of the stack registers as the arguments for complex numbers? I am also not able to use stored values for the arguments for complex numbers.
I really hope there is a simple way to do this, and that I do not have to write programs to do simple things like this, something that I am completely unfamiliar with.
BR,
(08-20-2015 10:41 PM)Merwedv Wrote: [ -> ]For example, how would I enter something like "5 theta pi"? When I try it the obvious way, I get a syntax error. Or if I would like to do something like "2*2 + 4i"?
I do not have a simple solution for the theta case, but the latter is simple and rather straightforward: 2 [ENTER] 2 [x] 4 [i] [+].
Assuming the calculator is set to RPN mode. In ALG mode you simply type "2x2+4i". ;-)
(08-20-2015 10:41 PM)Merwedv Wrote: [ -> ]Is there a way to use the value of the stack registers as the arguments for complex numbers?
Sure. If the real and complex parts are in Y and X, simply press [i] [x] [+] to get y+ix.
(08-20-2015 10:41 PM)Merwedv Wrote: [ -> ]I am also not able to use stored values for the arguments for complex numbers.
This can be done in the same way: [RCL] B [i] [x] [RCL] A [+]
Or, saving one stack register: [i] [RCL][x] B [RCL][+] A.
Dieter
Hi Dieter,
Thanks so much for your response. It does seem very obvious now that you clarified. I was regarding "i" as a operand, rather than an actual number, albeit complex, and that completely threw me off the right track. (led astray by the xiy notation).
As for "r /_ theta", since it is merely a shorthand of r*e^(j*theta), it is neither an operand nor a "number"(like i) and cannot be treated as such. I spend some time learning how to program the thing (not as difficult as I anticipated), and did the following to be able to use the X and Y registers to enter a complex number in the r /_ theta notation:
A001 LBL A
A002 REGYxCOS(REGX)
A003 ixREGZxSIN(REGY)
A004 +
A005 RTN
So it will take the Y-reg as the magnitude, and the X-reg as the angle, and place the complex result in X-reg, in either rectangular or polar notaion, depending on the diplay mode.
Cheers,
Merwe
(08-21-2015 09:05 PM)Merwedv Wrote: [ -> ]
A001 LBL A
A002 REGYxCOS(REGX)
A004 +
A005 RTN
Why don't you simply put it on a single line (and save one stack register)?
REGY*COS(REGX)+i*REGY*SIN(REGX)
You may also define this as an equation, so a simple EQN ENTER will turn X and Y into a complex number.
However, I would prefer a stack drop like this:
T          T
Z   XEQ A  T
Y    =>    Z
X         (complex number)
Which may be implemented in a short program this way:
LBL A
R↓
REGX*COS(REGT)+i*REGX*SIN(REGT)
X<>Y
CLx
RTN
Dieter
Yeah, your way is much better. Thanks again.
