07-06-2015, 12:57 PM
I have an HP9100B to repair (well, to try to repair). I have seen a huge amount of information avaliable in this forum and many documentation from Tony Duell and others. Thanks to all for your contributions! My HP9100B doesn't look very well externally, but internally looks pretty well (Clean and not evident burned components).
The display doesn't respond when turned on.
The error light turns on sometimes when I touch de keyboard.
A couple or three times, when I was trying to turn it on, the display showed figures with not so much sense.
From the information I have seen my conclusions/next steps could be:
- The Power source is working (fine). It is not frequent that it fails. Even the capacitors.
- The CRC tube works.
- I should remove the Card reader and check. Even the keyboard failure can cause the problem.
- The most frequent problems come from transistors failures. One single defective transistor can cause the problem. Am I right? Hence: check the transistors, but there are hundreds...any recommendation about where to start?
It is a pity IMMO, to have a big amount of disconnected information. Maybe it would be of help to create some kind of "checking protocol" to try to identify the problem of the HP9100Bs.
Thanks in advance to all.
Kind regards
Ignacio
Kind regards
Ignacio
