06-30-2015, 06:54 PM
After a long period of time Emu42 v1.19 is available at http://hp.giesselink.com.
Emu42 v1.19 integrate the same new feature like in Emu28, disabling the title and menu bar over the settings dialog. With disabled title and menu bar and a modified KML script defining one color as transparency color for the background bitmap (the GIF89a image decoder also supports the transparency color now) you also have the possibility to get a borderless shape of the calculator body now.
For best view you need an actual set of the Emu42 KML scripts using the new transparent feature. They are not such as perfect as you might expect. It took quite a lot of time from the amount of scripts and from the fact that they aren't made for transparent edges. Further I removed all beep patch files from the KML scripts, they are obsolete and should not be used any more. If you uninstall the old Emu42 version before installing the new version, the beep patch files will also removed from your system. You may use some 3rd party KML scripts which still contain the beep patch call, just remove the beep patch line from the script.
A complete list of bugfixes and changes is available here.
A final word to the Emu42 Pocket PC version 1.18. The new version only incorporate a bugfix already made in the Emu48 Pocket PC version last year. Because no Pocket PC / Windows Mobile v6 compatible devices are build any more I will quit the further development on Emu42PPC and Emu48PPC.
Christoph
Christoph
