06-23-2015, 04:54 PM
New versions should be up on the FTP now. Connectivity kit check for update will find them. If your network blocks direct connection, the direct link can be found at "ftp.hp.com/pub/calculators/Prime/".
This is a maintenance release addressing some of the issues identified on this and other forums, and internally.
Detailed release information for those interested:
Have fun!
Quote:HP Prime – Release Notes
Date Released: 2015/06/17
Internal Versions
Firmware Version: 2015 06 17 (8151)
Virtual Calculator Version: 2015 06 17 (8151)
Connectivity Kit: 2015 06 17 (8151)
Description
This maintenance release of the Prime Calculator firmware and associated PC software delivers fixes to outstanding issues. This document is not a complete list of all changes, but highlights specific items. All users of the HP Prime calculator are encouraged to upgrade for the best possible experience.
New Functionality (Connectivity Kit)
1. Improved sending of zipped applications using various methods
New Functionality (Calculator Software)
1. Theme variable to allow programmatic access to current system theme and color settings
2. Added PredX support for logistic fit in statistics 2 var
Resolved issues and changes excluding CAS
1. Removed ability to install on Windows XP as it is no longer supported
2. Resolved issues with the Define key and memory management view
3. Resolved issue with using program catalog RUN box and RPN input mode
4. Resolved issue with editing complex matrices through interface
5. Resolved issue with several matrix manipulation commands like REDIM
6. Resolved issue in connkit with opening Inference app from earlier firmware release
7. Resolved issue with unit saving in spreadsheet
8. Resolved issue where matrix would be linked after using M2:=M1
9. Resolved issue with display of constants in chooser
10. Resolved issue with several surveying units by increasing internal precision
11. Resolved issue with plot shading in some hypothesis tests
12. Resolved issue where colors in stat plotters not always matching definition in SYMB
13. Resolved issue with E- in a constant while in CAS
14. Resolved issue with Save in note catalog not using selected note but top note in list
15. Resolved issue with Copy/Paste of long strings
16. Resolved issue where non-exported app program variables appeared in vars->app
17. Resolved issue with CHOOSE command and choose fields in INPUT command
18. Resolved issue with digit separators when using Memory->Edit
19. Resolved issue with Lin Reg T Test plot in Inference
20. Resolved issue with dot plots containing large groups of data
21. Resolved issue with in versus inch units and µ prefix in CAS
Resolved issues and changes in CAS
1. Resolved issue with <= and >= in assumptions
2. Resolved issue with order of assumptions
3. Resolved issue with "translate" command and circles
4. Resolved issue with EIGENVAL and certain matrices
5. Resolved issue where isosceles_triangle command did not accept input in degrees
Have fun!
