06-22-2015, 10:32 PM
Hello all,
Would you be kind enough as to explain with an example how to do matrix multiplication in the 34s? So far I have only been able to invert them, mostly because all it takes is store the data in \(R_n\) and then call \(M^{-1}\) with the descriptor in \(x\). Quite easy.
As to multiply matrices, the manual says the descriptors should be in \(z\) and \(y\), the problem however is that I don't quite understand what should be in \(x\).
Very much appreciated.
Marcio
Marcio
