I cannot seem to get this program to work properly? It doesn't seem to do anything. But if I try to check the program code it says there's an syntax error on line 371?
A factory reset doesn't seem to help either.
Latest version, HP Prime virtual calculator and HP Prime physical calculator.
it takes some time to get used to it, but it works just fine.
2018version
Bode App: View
OR
Function App: for Plots
F1, has log Magnitude of Transfer function
F2, has Angle of Transfer function
F3, has Impulse Response of Transfer function
F4, has Step Response of Transfer function
F5, has Ramp Response of Transfer function
OR
Query / plot under Bode App CAS:
Tmag / plotfunc(Tmag)….. 20*log(Mag)
Tm / plotfunc(Tm) …… Mag
Tphase / plotfunc(Tphase)... Phase
Tp / plotfunc(Tp)……... Phase
Timpl / plotfunc(Timpl)…. Impulse Response
Tstep / plotfunc(Tstep)…. Step Response
Tramp / plotfunc(Tramp)…. Ramp Response
OR
Query / plot under under any App:
CtrlsSys.Tmag / plotfunc(CtrlSys.Tmag)….. 20*log(Mag)
CtrlSys.Tm / plotfunc(CtrlSys.Tm) …… Mag
CtrlSys.Tphase / plotfunc(CtrlSys.Tphase)... Phase
CtrlSys.Tp / plotfunc(CtrlSys.Tp)……... Phase
CtrlSys.Timpl / plotfunc(CtrlSys.Timpl)…. Impulse Response
CtrlSys.Tstep / plotfunc(CtrlSys.Tstep)…. Step Response
CtrlSys.Tramp / plotfunc(CtrlSys.Tramp)…. Ramp Response
The new app is amazing ! Extremely easy to use and powerful. Thank you !
Maybe in the future HP will consider including it in the firmware.
thanks toshk!
But, please, I need some other help to use it: should I install both Bode Plot (old) and CtrlSys?
How to initialise the program (CtrlSys)?
Salvo
(01-17-2018 03:24 PM)salvomic Wrote: [ -> ]thanks toshk!
Salvo
you don't need both apps, but they can co-exist.
same drill as old Bode Plot. BODE(.001,1000,[1],[2,3,4])
Then you can use view or function app
or query(type) various names on the command line
or plotfunc on CAS command line (click on tiny pic to show or click tiny pic to command line to edit the range of plot)
or type full qualify name on any app.
(01-17-2018 06:49 PM)toshk Wrote: [ -> ]you don't need both apps, but they can co-exist.
thank you, however maybe here both apps are not initialised or I'm not understanding, sorry.
I tried (beta v3):
plotfunc(CtrlSys.Tp) -> syntax error
BODE(.001,1000,[1],[2,3,4]) -> syntax error
Be patient, I'm trying again
Salvo
EDIT: oops! I miss always to do this
>>App>>Bode Plot>>Shift>>1>>Bode plot(App)>>Check
Now it's correctly initialised and I can try
EDIT 2: I'm pretty sure you would consider to upgrade also
this thread in the Library section of the Forum... thanks!
Hey there, I've been trying to use this APP and when I try to do the new install step (App>>Bode Plot>>Shift>>1>>Bode plot(App)>>Check) I get Syntax error in program line 341 is there a workaround this? or am I doing something wrong?
(02-11-2018 12:24 AM)videosloco23 Wrote: [ -> ]Hey there, I've been trying to use this APP and when I try to do the new install step (App>>Bode Plot>>Shift>>1>>Bode plot(App)>>Check) I get Syntax error in program line 341 is there a workaround this? or am I doing something wrong?
Sorry i can't reproduce the error at the line341; CtrlSys.Ymin:=MIN(C2);
(02-11-2018 06:56 AM)toshk Wrote: [ -> ] (02-11-2018 12:24 AM)videosloco23 Wrote: [ -> ]Hey there, I've been trying to use this APP and when I try to do the new install step (App>>Bode Plot>>Shift>>1>>Bode plot(App)>>Check) I get Syntax error in program line 341 is there a workaround this? or am I doing something wrong?
Which version of the calc are you using? I'm using 20180124 v133333 and I have the exact line as you but I keep getting Syntax error when checking, I only need to download the CtrlSys app right? nothing else is needed to use the app.
Hi, would someone explain how to step-by-step how to install the app and what commands are used?
I could not do anything at all, what values do I put on C1, C2 and C3?
Hello, here are some pictures I took ... what am I doing wrong?
What are the commands? Can anyone give an example?
what are the required settings?
When I connected my calculator it ended up being updated.
Hi, could you post a video with examples?
No settings to mess with.
Type BODE(w1,w2,poly[numer],poly[denom]) enter.
Hit the View key choose a plot. Viola!!
Read page1 of the thread.
You do not fancy the plot under the Ctrl App go into Function app for all the equations
Thank you for the great app.
Although I found it very slow to come back after "BODE(0.001,100,[1 15 50],[1 12 44 48])"
I know it's a tough transfer function, but the thing is (I saw it) that it generates all the data for the plots once you click enter. It should only generate the basic (the TF) and then when you select which plot, it process the thing you asked.
It's calculating too many things for the majority purposes (mag, phase, step).
Is it possible to change X for S in the transfer function?
I tried the update: it says insufficient data whenever I try to switch to plot view.
BODE(...) seems to do something because it takes quite a while for processing.
Any ideas?
For the @salvomic example: BODE(.001,1000,[1],[2,3,4])
If the PRIME is not in HOME mode, the simulator crashes.
In the app source code, the section for the RootLocus view is commented out in the 16JAN2018 version.
With that section uncommented, RootLocus view still does not work. Plot gives error
"S3 - Error:Insufficient statistics data".
The program source is quite difficult for me to understand, as I'm not 'experienced'; it also does not have any documentation or even a single comment in the source.
So yeah, it is definitely broken and does not implement all the features it can. Maybe the admins should edit the title to warn that the Root Locus part is unimplemented and that it does not work, because it still shows up on search results and therefore is confusing.
