04-27-2015, 03:54 PM
I don't fully understand how SEEKPT and SEEKPTA works in a program. I've got a program that works sometimes, but often it doesn't. My 41CV has an Extended Functions/Memory module and I have an HP-IL printer attached.
The most used program on my 41 requires a structured data file in Extended Memory. To check that file I wrote the following program to produce a print out:
01 LBL "XDATA"
02 SF 21
03 STO 01
04 LBL 01
05 FIX 0
06 RCL 01
07 INT
08 ACX
09 " : "
10 ACA
11 SEEKPT
12 GETX
13 FIX 3
14 ACX
15 PRBUF
16 ISG 01
17 GTO 01
18 END
I place the name of the data file in the Alpha register and the starting and ending registers along with the increment in X (s.eeeii) and sometimes the program will print the following:
59.06301
XEQ "XDATA"
59 : 163.288
60 : 168.990
61 : 174.850
62 : 180.749
63 : 186.623
(the data file is a lot larger but this serves for illustration)
But days later, running the program again, I got the error message "FL TYPE ERR". I tried changing line 11 to SEEKPTA but still got the error. The program halted on line 11, at this point the Alpha register contains " : ".
I rewrote the program a little so as not use the " : " separator thinking that since it was replacing the data file name in the Alpha register the calculator was now searching for a data file named " : ". I got it to work, but the format of the printout above is easier to read - and it worked at one time! (And it worked again yesterday after recovering from a MEMORY LOST.)
So I don't understand fully how to use these functions.
The manual is a little cryptic on how SEEKPT is used, at first I thought it was used for data files only. On re-reading it seems instead that it uses an assumed "working file", while SEEKPTA makes the named file the working file. I can't figure out how one would know the working file without specifying it in the Alpha register.
Can someone enlighten me?
01 LBL "XDATA"
02 SF 21
03 STO 01
04 LBL 01
05 FIX 0
06 RCL 01
07 INT
08 ACX
09 " : "
10 ACA
11 SEEKPT
12 GETX
13 FIX 3
14 ACX
15 PRBUF
16 ISG 01
17 GTO 01
18 END
59.06301
XEQ "XDATA"
59 : 163.288
60 : 168.990
61 : 174.850
62 : 180.749
63 : 186.623
