Arranging labels independently may not be a built in feature of the INPUT command, but in a desparate act of dogged determination you
achieve what you are after, (this is just a 'food for thought' notion, not a fully working example):
EXPORT Test()
LOCAL A:=0;
local black:=rgb(0,0,0),
cyan:=rgb(245,250,255),
white:=rgb(255,255,255),
blue:=rgb(0,0,255);
local title:="title",label:="Label";
rect_p(G0,0,0,320,240,cyan); // Clear G0 graphic screen.
rect_p(G0,0,0,320,18,black,blue); // Clear G0 "title"
rect_p(G0,132,107,155,125,black,white); // Clear a rectangle for use as an input field
textout_p(title,G0,160-3*length(title),2,3,white,40,blue); // Display "title" text
textout_p(label,G0,160,109,3,black,50,cyan); // Display "Label" on RIGHT side the input field <the main objective!>
textout_p(IP(A),G0,135,109,3,black,9,white); // This just forces "0" into the input field, as an example
textout_p("Enter value for Label",G0,0,204,3,black,320,cyan); // Help line shows just above a soft button choices
drawmenu("Edit","","","","Cancel","OK"); // This is a dummy soft button field.
wait(-1); // displays the above activity for awhile
