Of course it seems difficult to read the ROM (Brouhaha did an amazing work on this in the past) but we now have simulators and I believe the ROM is this file here:
C:\Program Files (x86)\Hewlett-Packard\HP 35s Virtual Calculator\Models\Model.dat
I checked the preliminary SPLB31A datasheet but couldn't figure out where the RESET vector is. We also don't have a clear idea of where the ROM is loaded though $C800 seems to be a good candidate. If anybody has a clue about that...
Did anybody already attempted to disassemble the 35s ROM?
Note: the ROM is actually embedded into the file 35s.sml
Found some constants in the ROM.
-4.95920119017593E2
3.03479606073615E1
-7.65594818140208E1
9.33584905660377
-1.21142857142857
0.4
.918938533204673
.5
7
90
100
180
200
Googling these values pointed me on "Hp48Sx Machine Language, Par Paul Courbis,Paul Courbis et Sébastien Lalande"
Anybody knows what these constants are?
Edit: ok found that these are constants used for various polynomial approximations. For example .918938533204673 is used during gamma log approximation.
(02-22-2015 10:26 AM)Tugdual Wrote: [ -> ]Edit: ok found that these are constants used for various polynomial approximations. For example .918938533204673 is used during gamma log approximation.
Ah, that's interesting. I always thought the 35s used some kind of approximation for Gamma resp. factorials. You may try the x! key with some non-integers so that the 35s has to evaluate the Gamma function. The result appears almost immediately. Try some integers and you'll notice an increasing lag as the values increase. 10! is returned instantly, but 150! requires roughly a second. Try 160! and the result appears immediately again. In fact the 35s seems to calculate factorials up to 158! by iterative multiplication, while 159! and up is evaluated by means of the Gamma function.
In this case not Γ, but ln Γ seems to be calculated. This would also explain slight errors for large arguments. Try 225,5! and the result is exact (1,89218764486 E434 with the last digit correctly rounded up from ...856). Try 225,6! and the last digit is 3 ULP low: 3,25375380207 E434 instead of ...210). This is the point where ln Γ exceeds 1000. Even if ln Γ is evaluated accurately to all internal 15 digits, there still is a potential absolute error of 1 E–11 in ln Γ which means a relative error of this order in Γ itself so that not more than 11 correct digits can be expected.
Dieter
I struggle with few technical aspects:
- lack of SPLB31A detailed doc (for example about registers usage)
- how to disassemble segmented ROM
- not sure I really understand how the segmented ROM works. I would imagine that before any jump the code is refreshing the BANK register and then proceeds with normal jump.
Providing that I'm not sure at all about the way the ROM is organized in the 35s.sml file, that is quite a lot of try/fail. I could verify that changing the file has an effect on the simulator, so the ROM is definitely there.
An interesting adventure anyway. I downloaded a copy and am poking around.
Looking at the hex dump of the file 35s.sml, there seems to be a code segment starting at $85c0. The output of the DCC6502 disassembler looks like some legit 6502/8502 code:
$85C0> D8: CLD ;
$85C1> A2 96: LDX #$96 ;
$85C3> A0 C8: LDY #$c8 ;
$85C5> EA: NOP ;
$85C6> 88: DEY ;
$85C7> D0 FC: BNE $85C5 ;
$85C9> A0 C8: LDY #$c8 ;
$85CB> CA: DEX ;
$85CC> D0 F7: BNE $85C5 ;
$85CE> A9 FF: LDA #$ff ;
$85D0> 85 07: STA $07 ;
$85D2> A9 00: LDA #$00 ;
$85D4> 85 06: STA $06 ;
$85D6> 85 08: STA $08 ;
BTW: There are some more "human readable" parts in the file, e.g. the constants library (speed of light, etc.) starting at $18750, some warning messages starting at $201c0, the messages of the self test starting at $e7f0, and a lot of function names and symbols every here and there, e.g. starting at $182f0.
If there is no checksum, one could easily poke around...
Using IDA you rapidly accumulate a lot legit 6502 fragments and it doesn't even look like it was compiled from C which I found surprising.
The difficulty is the ROM paging to know how to segment the file and detect ROM changes. There is a specific BANK register address (apparently $0000) where you select a segment and then it would map 2 blocks of 16kB respectively in $4000 and $8000.
I suspect that the ROM organization should be pretty much the same as for the 48g with basically a library by segment (I'm not an expert on 48g).
You can find SPLB31A datasheets
here
There is a test ROM located in $C000-$C7FF (not sure if it is the something built in the processor) and then you can have another range from $C800-$FFFF for a custom ROM.
So this is a 16kB area.
If you open the 35s.sml file with a text editor, you find the settings of the emulator at the beginning of the file:
; SPLB31A.
[SPLB31A_MEMORYMAP]
REG_ADDR_START =0x0000
REG_ADDR_END =0x003F
RAM_ADDR_START =0x0040
RAM_ADDR_END =0x10FF
LCD_ADDR_START =0x3E00
LCD_ADDR_END =0x3FFF
BANK_ADDR_START =0x4000
BANK_ADDR_END =0xBFFF
ROM_ADDRESS_START=0xC000
ROM_ADDRESS_END =0xFFFF
MAX_ADDRESS_SPACE=0x10000
MAX_BANK_NUM =8
[SPLB31A_IOPort]
Number=6
[SPLB31A_IOItem0]
Name=PortA
Address=0x08
Input = 0xFF
Output = 0xFF
[SPLB31A_IOItem1]
Name=PortB
Address=0x0A
Input = 0xFF
Output = 0xFF
[SPLB31A_IOItem2]
Name=PortC
Address=0x0B
Input = 0xFF
Output = 0xFF
[SPLB31A_IOItem3]
Name=PortD
Address=0x09
Input = 0x3F
Output = 0x3F
[SPLB31A_IOItem4]
Name=Keyscan1
Address=0x3B
Input = 0x00
Output = 0xFF
[SPLB31A_IOItem5]
Name=Keyscan2
Address=0x3C
Input = 0x00
Output = 0xFF
[SPLB31A_LCDSetting]
BaseAddress=0x3E00
SegmentNum=74
CommNum=32
Interval=16
bMinToMax=1
bVert=0
bMirror=1
ENDADDRESS=0x3FFF
[SPLB31A_BUSMEMORYINTERFACE]
BODYNAME =SPLB01A
DLL =BusMemoryInterface.DLL
BODYMAXSIZE =7
BODYINFO =SPLB30A_BUSMEMORYINTERFACE_BODY
ADDRESS_MAP =SPLB30A_BUSMEMORYINTERFACE_ADDRESS_MAP
CONDITON =SPLB30A_BUSMEMORYINTERFACE_COND
NOT_CONDITON =SPLB30A_BUSMEMORYINTERFACE_NOT_COND
DVP =OFF
DVP_RAM =SPLB30A_BUSMEMORYINTERFACE_BODY_DVP_RAM
DVP_ROM =SPLB30A_BUSMEMORYINTERFACE_BODY_DVP_ROM
BUSEXT_INTERFACE_COND=0x09
So with 8 banks (max) of 32K and 16K for the fixed ROM we're looking for a block of 272kB (278528 bytes) inside 35s.sml.
Now how is that organized? My best guess would be:
$C000 - $FFFF
BANK0-H -> remap to $8000
BANK0-L -> remap to $4000
BANK1-H -> remap to $8000
BANK1-L -> remap to $4000
BANK8-H -> remap to $8000
BANK8-L -> remap to $4000
That's all I know at the moment.
I wonder where the code is cold booting, possibly $C000, I wonder what registers are and how they work.
(02-22-2015 10:26 AM)Tugdual Wrote: [ -> ]Found some constants in the ROM.
-4.95920119017593E2
3.03479606073615E1
-7.65594818140208E1
9.33584905660377
-1.21142857142857
0.4
.918938533204673
.5
7
90
100
180
200
The same data block can be found in the
ROM entry points of the HP-48SX:
2B2DC %% HP:%%12
2B300 %% HP:%%60
2B31F %% %%-495.920119017593
2B343 %% %%30.3479606073615
2B36C %% %%-76.5594818140208
2B390 %% %%9.33584905660377
2B3B9 %% %%-1.21142857142857
2B3DD %% HP:%%.4
2B410 %% %%0.918938533204673
What makes me puzzling is why these values are stored in the HP 35S in ASCII format and not as binary or BCD numbers...
(02-22-2015 07:21 PM)Tugdual Wrote: [ -> ]Using IDA you rapidly accumulate a lot legit 6502 fragments and it doesn't even look like it was compiled from C which I found surprising.
Hmm... maybe you start to understand the problem/difficulty in fixing things... :-)
Completely non-documented (at least in anything but sparse chinese) source, non-English tools, extensive regions of assembly using non-standard assembly heavily dependent on non-documented features and registers requiring a close working relationship with the exact chip manufacturer (who doesn't have anyone who understands the chip anymore), no way to flash or change the firmware once flashed, etc
If you can imagine it, chances are it is part of the issue.
(02-24-2015 01:46 PM)Thomas Ritschel Wrote: [ -> ]What makes me puzzling is why these values are stored in the HP 35S in ASCII format and not as binary or BCD numbers...
Perhaps the compiler/assembler used didn't natively support the numerical data format used by those libraries, so that it would have been difficult to write those constants in the source code. If the data would have to be converted into another representation before it could be used, it wouldn't have harmed to store them in ASCII strings, anyway. ASCII strings of (almost) arbitrary length are supported by virtually all computer languages.
Another possibility might be that these numbers were meant to be patchable. It is quite common to store such numbers or strings in some easy recognizable and parsable format in binaries, so that they can be changed later on without having to recompile the sources, often even without having access to the sources (f.e. by OEMs or end-users).
Greetings,
Matthias
(02-24-2015 02:45 PM)matthiaspaul Wrote: [ -> ] (02-24-2015 01:46 PM)Thomas Ritschel Wrote: [ -> ]What makes me puzzling is why these values are stored in the HP 35S in ASCII format and not as binary or BCD numbers...
Greetings,
Matthias
I would say for the sake of consistency. The constants are also stored using ASCII because we need to pick a constant on screen and then it is represented as a tiny EQN inside the code.
Also whatever constant is entered manually is the same, a mini ASCII EQN.
Of course this is to the detriment of performance.
I wonder if the whole calculator operates in ASCII, a bit like BCD but ASCII version. That would be pretty unique!
(02-24-2015 04:43 PM)Tugdual Wrote: [ -> ]I would say for the sake of consistency. The constants are also stored using ASCII because we need to pick a constant on screen and then it is represented as a tiny EQN inside the code.
Haven't looked at the ROM a single "bit" but could it be that these are simply the ASCII representations of the constants for... display purposes (and that there is a binary representation elsewhere)?
(02-24-2015 04:56 PM)Han Wrote: [ -> ] (02-24-2015 04:43 PM)Tugdual Wrote: [ -> ]I would say for the sake of consistency. The constants are also stored using ASCII because we need to pick a constant on screen and then it is represented as a tiny EQN inside the code.
Good suggestion but the ASCII is definitely the value. If you change the ASCII string in the emulator you really see a different values during the code execution. Now there could be a cached binary version in memory.
