Full Version: Adding pic to post
FYI - Inserted photo attachments do not appear in preview mode.
When you reply to a post with a pic do you see the pic in the post when you preview?
Perhaps your preview preferences are phbbbbt!
(02-15-2015 05:13 PM)rprosperi Wrote: [ -> ]FYI - Inserted photo attachments do not appear in preview mode.
That's something I've noticed, too. I guess it has to do with the delayed upload of an attachment. As long as a post isn't "posted" its attachments aren't available, at least the generated URLs do not work yet.
There should be a difference when you edit a post with attachments. Those which are already present in the original posting should appear on a preview as well.
(02-15-2015 05:48 PM)Marcus von Cube Wrote: [ -> ]
Just tried and it's exactly as Marcus noted. I also played around a bit more and indeed it appears that attachments aren't 'seen' by the system until the message is saved.
I've played with this many times, and always bailed out thinking I was doing something wrong. Dumb. That's what the test forum is for... Dumb.
