12-29-2014, 08:38 PM
Program to calculate the area of a polygon by coordinates
[f] [PRGM]
[f] [P/R]
[f] [PRGM]
[f] [P/R]
REGISTERS USED:
R0: area of the polygon
R1: xi
R2: yi
NOTES:
X<>Y is SWAP
Rv is ROLL DOWN
INSTRUCTIONS:
1. The polygon must be in the 1st Cuadrant of Cartesian System
2. Must begin/end with P1(0,0) coordinate
3. The order to enter the coordinates is clockwise to normal figures and counter clockwise if the figure has a HOLE.
4. Before to enter the coordinates, you must be press [f][PRGM] and [f] [REGS] to begin in the 1st line of the program and clean all registers, including the STACK (X,Y,Z,T)
5. Enter in order the coordinates, P1, P2...Pn-1,P1 in this way: [X coordinate] [ENTER] [Y coordinate] [R/S]
6. At the end of the last point, P1(0,0) Press [RCL] [0] to obtain the desired area.
EXAMPLE 1.
For example, in a square (3x3=9 squared units):
[f][PRGM] [f] [REGS]
[0] [ENTER] [0] [R/S] *** P1(0,0)
[0] [ENTER] [3] [R/S] *** P2(0,3)
[3] [ENTER] [3] [R/S] *** P3(3,3)
[3] [ENTER] [0] [R/S] *** P4(3,0)
[RCL] [0]
RESULT = 9
EXAMPLE 2.
Example with a hole at center of the last square:
[0] [ENTER] [0] [R/S] *** P1 (0,0) (Begin with 0,0)
[0] [ENTER] [3] [R/S] *** P2 (0,3)
[3] [ENTER] [3] [R/S] *** P3 (3,3)
[3] [ENTER] [0] [R/S] *** P4 (3,0)
[0] [ENTER] [0] [R/S] *** P5 (0,0) (Close the polygon)
[1] [ENTER] [1] [R/S] *** P6 (1,1) (here the order of the points in counter clockwise)
[2] [ENTER] [1] [R/S] *** P7 (2,1)
[2] [ENTER] [2] [R/S] *** P8 (2,2)
[1] [ENTER] [2] [R/S] *** P9 (1,2)
[1] [ENTER] [1] [R/S] *** P10(1,1) (close the polygon that generate the hole)
[0] [ENTER] []0 [R/S] *** P11(0,0) (end with 0,0)
[RCL] [0]
RESULT=8 squared units
*ADITIONAL COMMENT: You can enter the first point (0,0) press only [R/S], only at the begin
Thanks for your aditional comments.
[f] [PRGM]
[f] [P/R]
[f] [PRGM]
[STO] [2]
[X<>Y]
[STO] [1]
[X<>Y]
[Rv]
[Rv]
[X<>Y]
[Rv]
[2]
[STO][-][0]
[RCL][2]
[RCL][1]
[f] [P/R]
REGISTERS USED:
R1: xi
R2: yi
NOTES:
X<>Y is SWAP
Rv is ROLL DOWN
INSTRUCTIONS:
EXAMPLE 1.
[RCL] [0]
RESULT = 9
EXAMPLE 2.
[RCL] [0]
