12-16-2014, 02:55 PM
12-20-2014, 04:05 AM
Diskette images of all these software packages are available at http://www.hpmuseum.net the wordstar package require the CP/M card and software.
12-20-2014, 04:40 AM
(12-20-2014 04:05 AM)Paul Berger (Canada) Wrote: [ -> ]Diskette images of all these software packages are available at http://www.hpmuseum.net the wordstar package require the CP/M card and software.
The issue is that the images on hpmuseum.net are for 3.5" disks and the 82901M uses 270K 5.25" disks. Using TeleDisk I was able to copy the 3.5" images to 5.25" HD disks, but they couldn't be read by the 82901M.
12-20-2014, 02:38 PM
One possible solution is to use HPdrive to emulate a 3.5 inch diskette. There is a utility to covert TD0 images to a format that HPdrive can use. From there you could copy all the files on the images to a 5.25 diskette. For the wordstar diskette you may need to copy the files under CP/M, however copying them in the BASIC OS may work to.
