(04-08-2015 11:51 AM)PANAMATIK Wrote: [ -> ] (04-08-2015 10:53 AM)Oulan Wrote: [ -> ]My woodstock cpu emulation does not have this bug ...
Perhaps as i started it with an HP67/97 emulation, it is more robust and without this bug
Olivier
I didn't know, that you wrote your own woodstock ACT emulator independently from Eric Smith's pioneer work "nonpareil". AFAIK the available patents do not reveal all secrets of the ACT instruction set and some research has to be done to get any firmware emulated without errors. I share my fully respect to anybody who has achieved that.
Bernhard
I have no idea whether Olivier developed it independently. All of the Woodstock microinstruction-level simulators I've actually disassembled (as well as some Classic- and Nut-series simulators) showed obvious signs of having been derived from Nonpareil, or from Jacques Laporte's code (which itself was partially derived from Nonpariel), but I haven't disassembled any code by Olivier.
In general I am dismayed at the number of people that have used Nonpareil-derived code commercially or otherwise in closed-source programs, without either honoring the GPL license terms, or contacting me. On the other hand, there have been several that were done with my permission.
The issue with label search on the 19C/29C/67/97 is caused by an obscure corner case of ACT behavior, regarding testing the P register for zero or non-zero immediately after an increment or decrement that wraps. I found it the hard way, and only years later saw an internal HP specification that basically said that the behavior in that situation was undefined. Obviously some very clever programmer at HP (possibly William Egbert) figured out that they could take advantage of the actual behavior of the chip, which was undocumented even within HP. Presumably after they had code that depended on it, they would have revised the specification, because they would have had to ensure that future versions of the ACT chip preserve the same behavior.
That someone might reverse-engineer the ACT instruction set and simulate it, and have the 67/97 simulation work correctly without having run into this problem and analyzing it to determine how to fix it to make the label search work correctly, seems *extremely* implausible, because the "obvious" behavior of that instruction in all other instances is contrary to what is needed for label search.
IIRC, HP did publish some tiny snippets of Woodstock microcode in a journal article, but not enough to actually determine a non-trivial portion of the instruction set, though enough to tell that the instruction encodings weren't the same as the Classic instruction set. There was an article in PPC Journal that included an analysis of what some HP-67 (or was it -97?) microinstructions did, but there were inaccuracies in the descriptions, and the author had only reverse-engineered it enough to identify specific microinstruction addresses useful for building an interface to an external device, actually in a manner similar to how the output capabilities of the HP-97S work.
Aside from the label search problem, the trickiest reverse-engineering I did on the Woodstock family was determining how the PIK (printer interface and keyboard) chip and CRC (card reader controller) chip work. HP provided a fairly complete general description of the PIK in a Journal article, albeit leaving some details for me to discover, but their CRC description was extremely cursory, and it took me quite a while to work out the details of the CRC.
