Hey guys i have been trying to calculate a simple PV and it just doesn't work ! i found this post here but for some reason my results are different, ay idea ?
http://www.hpmuseum.org/cgi-sys/cgiwrap/...ead=131585
FV=1.500
N=1.5
i=6%
pv= ? should be 1,376.15 But im getting 1,373.88
Thanks =D
Define "should be" :-)
Excel gives $1,374.46 to =PV(0.06,1.5,0,1500)
That's what the 10bII+, 17bII+, and the 12c in "C" mode (press STO EEX and solve this on the 12c).
So, I'm guessing this must be a TI model that has defined "should be" ? Again :-)
Partial periods require more information in order to solve them. Can you get Excel to give the 1376.15? If so, by what formula ?
That will help us know how to help. All questions are good, hence the smileys here.
(10-29-2014 07:48 PM)Gene Wrote: [ -> ]Define "should be" :-)
Using the Formula P=s/(1+rt)
So, P=1500/(1+(0.06*1.5))
P=1,376.15
And also if you checked up the link for the other Post, they say how to do it, but i still got different numbers, even doing the same steps
Franz, i need to do that on my calculator =/
aha. That's simple interest.
The financial calculators use compound interest for n > 1.
For example, using P = S / ( 1 + r x t ) for t = 5 years, you would have P = 1500 / ( 1 + 0.06 x 5 ) or 1153.85.
I am not aware of any financial calculator that handles simple interest built-in for situations where n or t in this case is > 1.
Sorry! You'll have to do it by hand or write a short program.
Store S in 00, Store r in 01, Store t in 02 and then as a program:
RCL 01 RCL 02 x 1 + RCL 00 X<>Y / GTO 00
would solve the present value in a simple interest circumstance.
(10-30-2014 02:47 AM)Gene Wrote: [ -> ]aha. That's simple interest.
For simple interest you could just use the following:
n = 1
i = 9 (= 6*1.5)
FV = 1500
Pressing PV should yield the requested -1376.15.
(10-30-2014 09:31 AM)Thomas Ritschel Wrote: [ -> ] (10-30-2014 02:47 AM)Gene Wrote: [ -> ]aha. That's simple interest.
n = 1
i = 9 (= 6*1.5)
FV = 1500
For some reason it worked this time! I was trying to follow the link that i posted but i wasnt getting the same results
And i would guess that there is no way to calculate simple n and i , right ?!
Thanks a lot for the help guys!
D
