10-12-2014, 11:38 PM
First of all, thanks to forum member Patrice for sharing a work in progress (His source code for the HP-16C N-Queen's Benchmark).
I have ported this code to the bit commands of the WP-34S which has resulted in doubling the speed of the N-Queens solution over the traditional WP-34S N-Queens benchmark.
Set Wordsize to 32.
Here is the code, starts at memory location 32. I also attach a .dat file so that this code can be loaded into the emulator:
Set Wordsize to 32.
WP-34S
32 [f] LBL C
33 [f] BASE 16
34 3
35 STO I
36 [h] CLx
37 STO 00 //Count
38 1
39 0
40 1
41 0
42 1
43 0
44 1
45 STO 02 //Queen
46 8
47 STO 01 //Line
48 [h] MASKR->X
49 X~Y //Mask width specifier got pushed onto stack above the mask
50 R Dn //Get rid of it
51 [h] SL 01
52 STO -> I //Mask
53 8
54 [h] X~I
55 X~Y
56 [f] LBL 02 //Byte to be tested is in Y. Bit to test ins in I
57 INC 00 //Count First increment the line counter
58 [h] BS?->I
59 [h] GTO 05
60 [f] LBL 03
61 [h] DSZ I
62 [h] GTO 02
63 X~Y
64 [h] X~I
65 INC 01 //Line
66 [h] DSZ I
67 RCL->I
68 [h] DSZ I
69 RCL->I
70 X~Y
71 [h] X~I
72 X~Y
73 [h] GTO 03
74 [f] LBL 05
75 X~Y
76 [h] X~I
77 RCL 02 //Queen
78 X~Y
79 [h] ISZ I
80 STO->I
81 STO J //Save the rotation count in the "TEST" register
82 R Dn //Get rid of it, and pull the rotation candidate into X
83 [h] RL->J //Rotate by the rotation count. TODO might be better way to do this: RL -> -> I Then could drop two lines above
84 [h] OR
85 DEC 01 //Line. Note: Might be better way to do this like: DSZ
86 RCL 01
87 [f] x=0? //Are we done?
88 [h] GTO 04 //Yes Done: Terminate
89 R Dn //No, Not done
90 RCL 03 //Mask
91 [h] NOT
92 [h] AND
93 [h] RR 09
94 [h] RRC 08
95 [h] RL 16
96 [h] RLC 08
97 [h] RR 07
98 ENTER
99 ENTER
100 ENTER
101 [h] RL 08
102 [h] OR
103 ENTER
104 [h] RL 16
105 [h] OR
106 RCL 03 //Mask
107 [h] AND
108 RCL L
109 [h] XOR
110 [f] X=0?
111 [h] GTO 06
112 [h] OR
113 [h] ISZ I
114 STO->I
115 8
116 [h] X~I
117 X~Y
118 [h] GTO 02
119 [f] LBL 06
120 8
121 STO + 00 //Count. Increment count by 8
122 INC 01 //Line Increment Line count by 1
123 RCL->I
124 [h] DSZ I
125 RCL->I
126 X~Y
127 [h] X~I
128 X~Y
129 [h] GTO 03
130 [f] LBL 04
131 RCL 00 //Count
132 [g] RTN //Solution: 8 4 1 3 6 2 7 5 In every second register above 3
