09-24-2014, 09:13 AM
Joe Horn posted the rules in a different thread.
They are worth linking to again here.
Anyway, on to the nitty gritty.
My first attempt for the 34S follows. The 34S has some advantages here. Date arithmetic and a built in primality tester. It isn't so good at long constants however, I almost wish I'd implemented merged constants which would save lots of steps. Oh well, too late for that now.
The four steps prepended with a minus sign can be removed trivially:
That makes forty steps. Not a bad first stab at the solution but I very much doubt this is even remotely close to the minimal.
- Pauli
- The initial label is obviously optional.
- LBL 01 is a subroutine called from one place. Make that a BACK branch instead and the RTN+1 statements become a SKIP branch to the instruction after the LBL 03 position.
- LBL 03 is a target of a single branch. Use a SKIP instead.
- CLx is a visual indication that the program has finished, more for debugging than anything else.
- Pauli
- 1 LBL A
2 STO I Need to seed this register to something small
3 RCL X Duplicate the input to give us a stopping value
4 DEC X Go back to December 31st of the previous year
5 SDL 003 this takes six steps and could probably
6 # 123 be improved. We want (y-1)*10000+1231
7 + which is 10000 y - 8769. On the 34S
8 SDL 001 this takes the same number of steps
9 INC X unless a short cut can be found
10 RCL Y Get our year back
11 INC X This time we go to Jan 1st of the following year
12 SDL 004 I.e. y * 10000 + 101
13 # 101
14 +
15 CF 00 Clear our flag
16 PRIME?
17 SF 00 But set it if Jan 1st is prime.
18 GTO 03 Skip to the date decrementer
- 19 LBL 01 Got a prime, check for twin
20 FC? 00
21 STO I Save if we've not had a prime before
22 FC?S 00
23 RTN+1 and return one step ahead
24 x[<->] I
25 XEQ 02 Get previous value and display
26 x[<->] I
27 XEQ 02 Display current value
28 RTN+1 Return with skip
29 LBL 00 Main loop check the date
30 PRIME?
31 XEQ 01 If it is prime, do stuff
32 CF 00 Not prime, clear our twin flag
- 33 LBL 03 Step back a day
34 SDR 004 The 34S only has yyyy.mmdd not
35 1 the desired yyyymmdd. Maybe in the 43S
36 +/-
37 DAYS+
38 SDL 004
39 x[>=]? Y Check for loop termination
40 GTO 00
- 41 CLx Visual indication of finished
42 LBL 02 Display if in range
43 x>? Y
44 STOP Use a PSE for less interaction
