08-16-2014, 09:05 PM
To get this arrangement:
4: Library 4 / CL Library in 2nd bank. 4LIB is the name.
5: Timer – physically plugged in.
6: PowerCL non-Extreme – Library 4 - PWRL
7: YFNP
8: AMC OS/X - 3 bank rom Library 4 – OSX3.
9: TVMY
A: Sandmath 3x3 – Library 4 version. SM33
B: Sandmath 3x3 – Library 4 version. (Continued)
So, here goes! Make the 41CL show MEMORY LOST
XEQ ALPHA MMUCLR ALPHA
First, let's get Library 4 put in the proper place.
For V3/V4 boards:
ALPHA 804040-8120 ALPHA
XEQ ALPHA YPOKE ALPHA
For V2 boards:
ALPHA 804040-803F ALPHA
Press OFF then ON
ALPHA PWRL ALPHA
XEQ ALPHA PLUGP ALPHA
ALPHA YFNP ALPHA
XEQ ALPHA PLUGH ALPHA
ALPHA OSX3 ALPHA
XEQ ALPHA PLUG1L ALPHA
ALPHA TVMY ALPHA
XEQ ALPHA PLUG1U ALPHA
ALPHA SM33 ALPHA
XEQ ALPHA PLUG2 ALPHA
XEQ ALPHA MMUEN ALPHA
Press OFF then ON. (Probably not necessary, but I did it anyway).
Voila! I must admit I feel really stupid because I struggled for a bit figuring this out. So, in case anyone else is suffering quietly and to come clean with my stupidity, here's a record for the world of what I did.
Notes:
1) SM33 is merely a rom that plugs into an entire port. Don't worry that it has 2 pages each containing 3 banks. It's just the same as plugging in an 8K rom like the PPCM.
2) OSX3 is a 3 bank library 4 aware version of the CCD/OSX style rom. Even though it is 3 banks, it is plugged in using the same command you would use to plug in a 4K rom.
3) PowerCL is the Library 4 aware version of the 41CL Utils rom. If you are using PowerCL, you do not need any version of the 41CL Utilities rom. And, note that I have it plugged into page 6. It can safely sit in the printer page (as long as you are not using the printer of course). It is one of the few roms that can sit there and operate properly.
4) I have used YFNP because that is the version of the Y-functions to use if you are using the PowerCL module. If you use the PowerCL Extreme library 4 aware rom, then you should use YFNX instead of YFNP.
5) Note the different ALPHA entry for the Library 4 YPOKE command for V2 vs. V3/V4 41CL boards.
Questions? I had a bunch a week ago. Be glad to try to help anyone.
7: YFNP
9: TVMY
For V3/V4 boards:
For V2 boards:
Press OFF then ON
ALPHA PWRL ALPHA
ALPHA YFNP ALPHA
ALPHA OSX3 ALPHA
ALPHA TVMY ALPHA
ALPHA SM33 ALPHA
Notes:
