06-19-2014, 03:46 PM
Like me, you may have also missed the excellent article in the old forum by Guillermo Castarés with programs to solve electric circuits:
http://www.hpmuseum.org/software/41/41elcirc.htm
The approached he followed was remarkable in two aspects – first it had a precise usage of the PVT routine from the Math Pac using complex matrices; which wasn’t documented at all in the flimsy manual that was provided with that module.
More interesting was his idea of using ASCII files to define the circuit topology: type, elements, values, etc. This approach allows a very effective use of the system capabilities, without the need to re-enter all data each time allowing quick what-if scenarios for component value changes.
Not to mention that you could build up a library of circuits in X-memory very nicely. For example, these are the files for the Math Pac and the Advantage Pac manuals (Remember student “AC Dimmer”?), listed with their respective solutions.
I’ve taken the opportunity to update the program, replacing the PVT call with the much faster MSYS in the Advantage Pac (or in the SandMatrix, of course); an splendid example of the MCODE advantages.
And to round up the task a new data-entry program is also provided, which builds the ASCII file from the scratch in an interactive way just entering the information in the prompts.
The new data-entry program “EEE” is completely independent, and its end result is an ASCII file to use as input for “EEA”, the circuit solver program.
Raw files are attached if you want to take them for a spin. Note that they use functions form the AMC_OSX module for a more convenient UI – but you can replace them with those in the CCD with the same names.
Modified EEA Program follows - maintains the same logic as the original to read the circuit file and create the system matrices, only slightly modified the data output routine to account for the differences between PVT and MSYS. Refer to the original article for user instructions and documentation.
Hope you enjoy it - Many thanks to Guillermo for the original contribution!
MPAC ACDIM
I4 0 I2
0V1 34 0 1 0V1 5 0
0R1 1 2 0Z1 10
1R2 1 3 1Z2 0 200
0R2 1 4 0Z2 0 -30
2R3 1 5 END
0R3 1
3R4 1 I1 = 0.0372 + 0.1311
0R4 2 I2 = 0.0437 + 0.1543
END
I1 = 21
I2 = 8
I3 = 3
I4 = 1
1 LBL "EEE"
2 "NAME? "
3 PMTA
4 15
5 SF 25
6 CLFL
7 FC?C 25
8 CRFLAS
9 ,
10 SEEKPTA
11 "TYPE? VI"
12 PMTK
13 CF 02
14 E
15 X#Y?
16 SF 02
17 "V"
18 FS? 02
19 "I"
20 CLA
21 XTOA
22 APPREC
23 "#NODE"
24 FS? 02
25 "#LOOP"
26 "|-S=?"
27 PROMPT
28 STO 02
29 CLA
30 ARCLI
31 APPCHR
32 "ELMNTS=?"
33 PROMPT
34 E3/3+
35 STO 00
36 LBL 00
37 CF 00
38 CLA
39 RCL 00
40 ARCLI
41 "|-: "
42 FC? 02
43 "|-I"
44 FS? 02
45 "|-V"
46 "|-RGLCXBYZY"
47 PMTK
48 XEQ IND X
49 STO 01
50 LBL 12
51 "FROM^TO=?"
52 PROMPT
53 X=Y?
54 GTO 12
55 RCL 02
56 X<Y?
57 GTO 12
58 X<> Z
59 RCL 02
60 X<Y?
61 GTO 12
62 RDN
63 XEQ 10
64 0
65 "VALUE=?"
66 FS? 00
67 "IM^RE=?"
68 PROMPT
69 XEQ 11
70 FS? 00
71 XEQ 11
72 ISG 00
73 GTO 00
74 "END"
75 APPREC
76 RTN
77 LBL 01
78 SF 00
79 86
80 FC? 02
81 73
82 RTN
83 LBL 02
84 82
85 RTN
86 LBL 03
87 71
88 RTN
89 LBL 04
90 76
91 RTN
92 LBL 05
93 67
94 RTN
95 LBL 06
96 88
97 RTN
98 LBL 07
99 66
100 RTN
101 LBL 08
102 SF 00
103 90
104 RTN
105 LBL 09
106 SF 00
107 89
108 RTN
109 LBL 10
110 CLA
111 ARCLI
112 RCL 01
113 XTOA
114 X<> Z
115 ARCLI
116 "|- "
117 APPREC
118 RTN
119 LBL 11
120 CF 01
121 CLA
122 FRC
123 X=0?
124 SF 01
125 X<> L
126 FS? 01
127 ARCLI
128 FC? 01
129 ARCL X
130 "|- "
131 APPCHR
132 X<>Y
133 END
289 bytes
1 LBL " EEA"
2 CLRG
3 CLX
4 SEEKPTA
5 GETREC
6 ATOX
7 STO 09
8 ANUM
9 ST+ X
10 STO 14
11 X^2
12 LASTX
13 ST+ X
14 +
15 15
16 +
17 SF 25
18 ARCL IND X
19 FC?C 25
20 PSIZE
21 SF 00
22 SF 01
23 LBL 08
24 GETREC
25 AVIEW
26 ATOX
27 48
28 -
29 STO 00
30 ATOX
31 STO 07
32 ATOX
33 48
34 -
35 STO 01
36 ANUM
37 STO 02
38 ATOX
39 LBL 09
40 ATOX
41 44
42 X<=Y?
43 GTO 09
44 CLX
45 ANUM
46 STO 03
47 CLA
48 RCL 09
49 XTOA
50 "|-ELS"
51 ASTO X
52 XEQ IND X
53 FC? 00
54 GTO 07
55 FS? 02
56 XEQ 01
57 FC? 02
58 XEQ 03
59 GTO 08
60 LBL 07
61 "WAIT…"
62 AVIEW
63 RCL 14
64 X^2
65 LASTX
66 +
67 14
68 +
69 STO 00
70 "R"
71 AIP
72 RCL 14
73 2E-3
74 +
75 MATDIM
76 RCL 14
77 E3
78 /
79 RCL 14
80 STO 13
81 +
82 ASTO 12
83 "R14"
84 MATDIM
85 "|-,"
86 ARCL 12
87 MSYS
88 LBL 10
89 RCL 13
90 2E3
91 /
92 E
93 +
94 STO 01
95 LBL 12
96 RCL 00
97 RCL 01
98 ST+ X
99 E
100 -
101 +
102 STO 02
103 CLA
104 RCL 09
105 XTOA
106 RCL 01
107 AIP
108 ASTO 10
109 "|-(RE)="
110 ARCL IND 02
111 PROMPT
112 CLA
113 ARCL 10
114 "|-(IM)="
115 RCL 13
116 RCL 02
117 +
118 ARCL IND X
119 PROMPT
120 ISG 01
121 GTO 12
122 GTO 10
123 ….
the rest is as the original
[code]
