06-06-2014, 03:24 PM
06-06-2014, 04:08 PM
Nope. Now would you have anywhere near enough speed to handle the data coming in. That was why the module to read, parse and display the data was made as a C binary blob.
06-06-2014, 05:02 PM
Well, sure, but you can imagine an RPL command to the StreamSmart that says in effect, do a collection run on these sensors at this sample rate, and then return the results as a list or matrix object. All the heavy lifting could still be done in the binary code. Seems like a little bit of a missed opportunity.
That said, thanks for the quick answer.
- John
- John
06-07-2014, 01:41 PM
(06-06-2014 04:08 PM)Tim Wessman Wrote: [ -> ]That was why the module to read, parse and display the data was made as a C binary blob.Is the data available as e.g. a list to be further processed within a program?
From the emulator, it is not obvious how things work. The 39gII manual does mention this app, but doesn't explain how it works.
A video demo and some more information would be very nice as 100 EUR for the StreamSmart isn't easily spent without knowing what can be done with it.
