Apparently there's a bug in the 95LX, and doing a hard reset (Ctrl-Shift-On) will blast a couple specific bytes near the end of the first 512 KB of RAM. These bytes may be within your current RAM disk (and are guaranteed to be on the 512 KB model). Does anybody have the UNRESET utility mentioned in this article?
http://www.palmtoppaper.com/ptphtml/6/ptp6006a.htm
how did you get along with sorting out the 'battery low' fault?
cheers,
rob :-)
(05-25-2014 03:36 PM)robert rozee Wrote: [ -> ]how did you get along with sorting out the 'battery low' fault?
cheers,
rob :-)
Works great! I just patched it up last night, actually, since I only recently got home from the hospital. I've got a pretty fine-point tip for my iron, and I was able to work the old cap off by alternating sides and gently applying pressure. Then it was a pretty simple matter to slap the new one in place. I popped in some AAs that I knew didn't have a full charge, and Setup told me they had about 1/3 left, so I'm assuming it's working as expected.
Interesting how just that particular cap fails consistently in the 512 KB models. Did HP buy a bad batch or something?
Now if I could just find a copy of DOS 3.22 to load some of the commands/utilities that aren't in ROM (attrib in particular). All I've been able to find are 3.2, 3.21, and 3.3, and the commands from those all whine about incorrect DOS version.
(05-25-2014 04:04 PM)Dave Britten Wrote: [ -> ]Interesting how just that particular cap fails consistently in the 512 KB models. Did HP buy a bad batch or something?
It could have been as simple as that. My company has been bitten by bad batches of capacitors in the past. We are now very picky about our sources.
Traditionally electrolytic capacitors tend to have a more limited lifespan compared to other electronic parts, primarily because of their "wet" electrolytic dielectric material and construction.
The worst example of bad capacitors I have heard of involved electrolytic capacitors produced by certain Taiwanese manufacturers around the 1999-2007 time frame. See:
http://en.wikipedia.org/wiki/Capacitor_plague
(05-25-2014 06:02 PM)Steve Simpkin Wrote: [ -> ]The worst example of bad capacitors I have heard of involved electrolytic capacitors produced by certain Taiwanese manufacturers around the 1999-2007 time frame. See:
Yeah, I think we ended up with a couple dozen self-destructed HP desktops at work around 2006-2007. And it's getting REALLY hard to find a working Sega GameGear these days.
(05-25-2014 04:04 PM)Dave Britten Wrote: [ -> ]Now if I could just find a copy of DOS 3.22 to load some of the commands/utilities that aren't in ROM (attrib in particular). All I've been able to find are 3.2, 3.21, and 3.3, and the commands from those all whine about incorrect DOS version.
Maybe some of the FreeDOS utilities work:
http://www.ibiblio.org/pub/micro/pc-stuf...files/dos/
