05-22-2014, 05:36 AM
05-22-2014, 06:10 AM
From the code I'd say: ( y mat -> r )
Where mat is a matrix descriptor and y is the element you search.
/* Find a specified element in a matrix
LBL'MFD'
ABS
M-ALL
x[<->] Y
m_find_loop:: x=?[->]Y
JMP m_found
ISG Y
JMP m_find_loop
m_found:: DROP
RTN
05-22-2014, 06:51 AM
To post #2:
Thank you.
I don't understand r.
For 5,6,7,8 stored in registers 20 to 23
stack y: 55 x: 20.0401 returns 24.02301
and
stack y: 7 x: 20.0401 returns 22.02301
Presumably the second result indicates "found"? How should this result be interpreted?
Thank you.
and
05-22-2014, 07:10 AM
You probably want the index of the element. The matrix descriptor is still in the last x register. Therefore you can use:
For 7 you get (x, y) = (3, 1). For 55 you get an Error: Out of range.
RCL L
M.IJ
05-22-2014, 07:33 AM
To post #4:
Thank you & yes that is the info I needed.
Will now get to work on Shanks SQFF.
