03-08-2019, 08:45 AM
Trying to speed up code I found this strange behavior:
With the following program named test01
The speed of tt02 function depend on the number of local functions defined in the program.
On a virtual Prime I got an average of 4.7 seconds for the TEVAL(tt02).
When I remove the 100 useless local ffxx functions in the program I got an average of 3.7 seconds for the TEVAL(tt02).
TEVAL(tt00) is still at 5.5 seconds and TEVAL(tt01) is still at 5.7 seconds.
On a real program the use of EVAL(list(I)) is even slower than using CASE constructions, which is a very strange behavior.
I got the same behavior on a real Prime too.
More fun about speed:
Use the following program
Run it several times and look at the numbers ... sometimes 10 seconds are lost somewhere ...
Generally the bevahior is VERY erratic, even for a such complex system as the PRIME (it is my own opinion). I agree that some stuff must be running at lower level than USER use but such erratic behavior is somewhat strange (nothing very reproducable).
#pragma mode(separator(.,;) integer(h32))
LOCAL ff00() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff01() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff02() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff03() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff04() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff05() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff06() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff07() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff08() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff09() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff10() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff11() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff12() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff13() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff14() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff15() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff16() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff17() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff18() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff19() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff20() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff21() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff22() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff23() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff24() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff25() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff26() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff27() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff28() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff29() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff30() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff31() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff32() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff33() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff34() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff35() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff36() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff37() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff38() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff39() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff40() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff41() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff42() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff43() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff44() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff45() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff46() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff47() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff48() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff49() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff50() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff51() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff52() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff53() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff54() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff55() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff56() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff57() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff58() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff59() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff60() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff61() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff62() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff63() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff64() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff65() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff66() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff67() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff68() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff69() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff70() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff71() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff72() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff73() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff74() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff75() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff76() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff77() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff78() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff79() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff80() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff81() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff82() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff83() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff84() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff85() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff86() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff87() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff88() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff89() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff90() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff91() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff92() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff93() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff94() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff95() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff96() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff97() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff98() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL ff99() BEGIN FOR I FROM 1 TO 99 DO A:=A+1; END;END;
LOCAL f0() BEGIN A:=10;END;
LOCAL f1() BEGIN A:=20;END;
LOCAL f2() BEGIN A:=30;END;
LOCAL f3() BEGIN A:=40;END;
LOCAL f4() BEGIN A:=50;END;
LOCAL f5() BEGIN A:=60;END;
LOCAL f6() BEGIN A:=70;END;
LOCAL f7() BEGIN A:=80;END;
LOCAL f8() BEGIN A:=90;END;
LOCAL f9() BEGIN A:=100;END;
LOCAL fA() BEGIN A:=110;END;
LOCAL fB() BEGIN A:=120;END;
LOCAL fC() BEGIN A:=130;END;
LOCAL fD() BEGIN A:=140;END;
LOCAL fE() BEGIN A:=150;END;
LOCAL fF() BEGIN A:=160;END;
LOCAL ff={'f0','f1','f2','f3','f4','f5','f6','f7','f8','f9','fA','fB','fC','fD','fE','fF'};
LOCAL sel00() BEGIN
CASE
IF J=0 THEN A:=10; END;
IF J=1 THEN A:=20; END;
IF J=2 THEN A:=30; END;
IF J=3 THEN A:=40; END;
IF J=4 THEN A:=50; END;
IF J=5 THEN A:=60; END;
IF J=6 THEN A:=70; END;
IF J=7 THEN A:=80; END;
IF J=8 THEN A:=90; END;
IF J=9 THEN A:=100; END;
IF J=10 THEN A:=110; END;
IF J=11 THEN A:=120; END;
IF J=12 THEN A:=130; END;
IF J=13 THEN A:=140; END;
IF J=14 THEN A:=150; END;
DEFAULT A:=160;
LOCAL sel01() BEGIN
CASE
IF J=0 THEN f0(); END;
IF J=1 THEN f1(); END;
IF J=2 THEN f2(); END;
IF J=3 THEN f3(); END;
IF J=4 THEN f4(); END;
IF J=5 THEN f5(); END;
IF J=6 THEN f6(); END;
IF J=7 THEN f7(); END;
IF J=8 THEN f8(); END;
IF J=9 THEN f9(); END;
IF J=10 THEN fA(); END;
IF J=11 THEN fB(); END;
IF J=12 THEN fC(); END;
IF J=13 THEN fD(); END;
IF J=14 THEN fE(); END;
DEFAULT fF();
LOCAL sel02() BEGIN
EVAL(ff(J));
LOCAL tt00() BEGIN
B:=0;
FOR I FROM 1 TO 1000000 DO
J:=(I MOD 16);sel00();B:=B+A;
PRINT(B);
LOCAL tt01() BEGIN
B:=0;
J:=(I MOD 16);sel01();B:=B+A;
PRINT(B);
LOCAL tt02() BEGIN
B:=0;
J:=(I MOD 16)+1;sel02();B:=B+A;
PRINT(B);
EXPORT test01()
PRINT();
PRINT(TEVAL(tt00));
PRINT(TEVAL(tt00));
PRINT(TEVAL(tt01));
PRINT(TEVAL(tt01));
PRINT(TEVAL(tt02));
PRINT(TEVAL(tt02));
#pragma mode( separator(.,;) integer(h32) )
local b:=0;
LOCAL tt0() BEGIN
local a:=0;
FOR a FROM 1 TO 1000000 DO
LOCAL tt1() BEGIN
FOR b FROM 1 TO 1000000 DO
LOCAL tt2() BEGIN
FOR A FROM 1 TO 1000000 DO
EXPORT test02()
PRINT();PRINT("");
PRINT(TEVAL(tt0));
PRINT(TEVAL(tt0));
PRINT(TEVAL(tt1));
PRINT(TEVAL(tt1));
PRINT(TEVAL(tt2));
PRINT(TEVAL(tt2));
