Full Version: Major bug on G2
When making some test to optimize some code I got a very nasty bug
Program leads to "reboot screen"
"Your HP Prime had a
problem and will
will reboot in 3 seconds" ...
got the trouble even after CFO,reset finally the problem disappear ... then reappears
AFTER CFO-ON, format C:, reset
mem INFO gives Memory 246.86MB, Storage 461.68MB
next one, reset
mem INFO gives Memory 246.93MB, Storage 461.59MB
next one with format C:, reset
mem INFO gives Memory 246.88MB, Storage 461.68MB
So it seems that I definitely lost 256MB of ram Sad
--EDIT--
Or I was misreading the info at first, I think that I saw Memory about 400MB but
as it seems that the G2 only got a 256MB ram chip so I was certainly misreading ...
So ram seems ok
--EDIT--
CFO screen
Besta V1.0 EA656 DIAGNOSTIC
DATA: V14181 OS(4M):2.1
ONLY RECH: 4.25V BOOT V2.060.650
SLC 512MB SLC
1.L/B TEST 8.TP FW Refresh
2.M/B TEST 9.RESET
3.F/A TEST A.Version Info
4.FLS Utility B.DEEP MODE
5.Evaluation C.POWER OFF MODE
6.RELIABILITY
7.USB TEST
SERIAL NO: NAANNNNNAN
EA656 Version Info
DATA Version : V14181
OS Version : 2.1
PCB Version : D
Touch IC FW Ver :GT5688-516
EVALUATION/SRAM/SRAM TEST
5.FULL TEST : OK
All tests seems ok
First run after CFO format reset was ok, then the pb re-appear (running prog with calc connected on USB)
Nexts runs leads to reboot too even with calc disconnected from USB
Program follows as source (sorry for the size)
#pragma mode(separator(.,;) integer(h16))
LOCAL rA=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
LOCAL rB=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
LOCAL rC=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
LOCAL rM=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
LOCAL rN=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
LOCAL rZ=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
LOCAL rT=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
LOCAL first=0;
LOCAL last=0;
LOCAL ptr=0;
LOCAL pp=2;
LOCAL pq=12;
LOCAL base=10;
LOCAL cy=0;
LOCAL p_cy=0;
LOCAL opcode=#0:16h;
LOCAL code=#0:16h;
LOCAL regZero(dest)
 FOR I FROM first TO last DO
  0▶dest(I);
 RETURN dest;
LOCAL regCopy(src,dest) BEGIN
  src(I)▶dest(I);
 RETURN dest;
LOCAL regAdd(src1,src2,dest) BEGIN
  src1(I)+src2(I)+cy▶dest(I);
  IF dest(I)>=base THEN
   dest(I)-base▶dest(I); 1▶cy;
  ELSE
   0▶cy;
 RETURN dest;
LOCAL regSub(src1,src2,dest) BEGIN
  src1(I)-src2(I)-cy▶dest(I);
  IF dest(I)<0 THEN
   dest(I)+base▶dest(I); 1▶cy;
  ELSE
   0▶cy;
 RETURN dest;
LOCAL regTestNE(src1,src2) BEGIN
  IF src1(I)≠src2(I) THEN 1▶cy;BREAK; END;
LOCAL regShiftR(dest) BEGIN
  IF I=last THEN 0▶dest(I);
  ELSE dest(I+1)▶dest(I);
 RETURN dest;
LOCAL regShiftL(dest) BEGIN
 FOR I FROM last DOWNTO first DO
  IF I=first THEN 0▶dest(I);
  ELSE dest(I-1)▶dest(I);
 RETURN dest;
LOCAL opArith2() BEGIN
 IF code(2) THEN   // 1xx
  IF code(1) THEN  // 11x
   IF code(0) THEN // 7 s
    14▶F; 14▶L;
   ELSE            // 6 m
    4▶F; 13▶L;
  ELSE             // 10x
   IF code(0) THEN // 5 xs
    3▶F; 3▶L;
   ELSE            // 4 pq
    pp+1▶F;pq+1▶L;
    IF F>L THEN 14▶L; END;
    IF F>14 THEN 1▶F; END;
    IF L>14 THEN 1▶L; END;
 ELSE              // 0xx
  IF code(1) THEN  // 01x
   IF code(0) THEN // 3 w
    1▶F;14▶L;
   ELSE            // 2 wpt
    1▶F;IFTE(ptr,pp,pq)+1▶L;
  ELSE             // 00x
   IF code(0) THEN // 1 x
    1▶F; 3▶L;
   ELSE            // 0 pt
    IFTE(ptr,pp,pq)+1▶F;F▶L;
 IF code(3) THEN     // 1xxxx
  IF code(4) THEN    //  11xxx
   IF code(5) THEN   //   111xx
    IF code(6) THEN  //    1111x
     IF code(7) THEN //     31 ASL
//       regShiftL(rA)▶rA;
 FOR I FROM L DOWNTO F DO
  IF I=F THEN 0▶rA(I);
  ELSE rA(I-1)▶rA(I);
     ELSE            //     30 CSR
//       regShiftR(rC)▶rC;
 FOR I FROM F TO L DO
  IF I=L THEN 0▶rC(I);
  ELSE rC(I+1)▶rC(I);
    ELSE             //    1110x
     IF code(7) THEN //     29 BSR
//       regShiftR(rB)▶rB;
  IF I=L THEN 0▶rB(I);
  ELSE rB(I+1)▶rB(I);
     ELSE            //     28 ASR
//      regShiftR(rA)▶rA;
  IF I=L THEN 0▶rA(I);
  ELSE rA(I+1)▶rA(I);
   ELSE              //   110xx
    IF code(6) THEN  //    1101x
     IF code(7) THEN //     27 ?A#C
//      regTestNE(rA,rC);
  IF rA(I)≠rC(I) THEN 1▶cy;BREAK; END;
     ELSE            //     26 ?A#0
//      regTestNE(rA,rZ);
  IF rA(I)≠0 THEN 1▶cy;BREAK; END;
    ELSE             //    1100x
     IF code(7) THEN //     25 ?A<B
//      regSub(rA,rB,rT);
  rA(I)-rB(I)-cy▶T;
  IF T<0 THEN
   1▶cy;
  ELSE
   0▶cy;
     ELSE            //     24 ?A<C
//      regSub(rA,rC,rT);
  rA(I)-rC(I)-cy▶T;
  IF T<0 THEN
   1▶cy;
  ELSE
   0▶cy;
  ELSE               //  10xxx
   IF code(5) THEN   //   101xx
    IF code(6) THEN  //    1011x
     IF code(7) THEN //     23 ?C#0
//      regTestNE(rC,rZ);
  IF rC(I)≠0 THEN 1▶cy;BREAK; END;
     ELSE            //     22 ?B#0
//      regTestNE(rB,rZ);
  IF rB(I)≠0 THEN 1▶cy;BREAK; END;
    ELSE             //    1010x
     IF code(7) THEN //     21 C=-C-1
//      1▶cy;regSub(rZ,rC,rC)▶rC;
 1▶cy;
  -rC(I)-cy▶rC(I);
  IF rC(I)<0 THEN
   rC(I)+base▶rC(I); 1▶cy;
  ELSE
   0▶cy;
     ELSE            //     20 C=-C
//      regSub(rZ,rC,rC)▶rC;
  -rC(I)▶rC(I);
  IF rC(I)<0 THEN
  ELSE
   0▶cy;
   ELSE              //   100xx
    IF code(6) THEN  //    1001x
     IF code(7) THEN //     19 C=C-1
//      1▶cy;regSub(rC,rZ,rC)▶rC;
 1▶cy;
  rC(I)-cy▶rC(I);
  IF rC(I)<0 THEN
  ELSE
   0▶cy;
     ELSE            //     18 C=A-C
//      regSub(rA,rC,rC)▶rC;
  rA(I)-rC(I)-cy▶rC(I);
  IF rC(I)<0 THEN
  ELSE
   0▶cy;
    ELSE             //    1000x
     IF code(7) THEN //     17 C=C+1
//      1▶cy;regAdd(rC,rZ,rC)▶rC;
 1▶cy;
  rC(I)+cy▶rC(I);
  IF rC(I)>=base THEN
   rC(I)-base▶rC(I); 1▶cy;
  ELSE
   0▶cy;
     ELSE            //     16 C=A+C
//      regAdd(rA,rC,rC)▶rC;
  rA(I)+rC(I)+cy▶rC(I);
  IF rC(I)>=base THEN
  ELSE
   0▶cy;
 ELSE                // 0xxxx
  IF code(4) THEN    //  01xxx
   IF code(5) THEN   //   011xx
    IF code(6) THEN  //    0111x
     IF code(7) THEN //     15 C=C+C
//      regAdd(rC,rC,rC)▶rC;
  rC(I)+rC(I)+cy▶rC(I);
  IF rC(I)>=base THEN
  ELSE
   0▶cy;
     ELSE            //     14 A=A-C
//      regSub(rA,rC,rA)▶rA;
  rA(I)-rC(I)-cy▶rA(I);
  IF rA(I)<0 THEN
   rA(I)+base▶rA(I); 1▶cy;
  ELSE
   0▶cy;
    ELSE             //    0110x
     IF code(7) THEN //     13 A=A-1
//      1▶cy;regSub(rA,rZ,rA)▶rA;
 1▶cy;
  rA(I)-cy▶rA(I);
  IF rA(I)<0 THEN
  ELSE
   0▶cy;
     ELSE            //     12 A=A-B
//      regSub(rA,rB,rA)▶rA;
  rA(I)-rB(I)-cy▶rA(I);
  IF rA(I)<0 THEN
  ELSE
   0▶cy;
   ELSE              //   010xx
    IF code(6) THEN  //    0101x
     IF code(7) THEN //     11 A=A+1
//      1▶cy;regAdd(rA,rZ,rA)▶rA;
 1▶cy;
  rA(I)+cy▶rA(I);
  IF rA(I)>=base THEN
   rA(I)-base▶rA(I); 1▶cy;
  ELSE
   0▶cy;
     ELSE            //     10 A=A+C
//      regAdd(rA,rC,rA)▶rA;
  rA(I)+rC(I)+cy▶rA(I);
  IF rA(I)>=base THEN
  ELSE
   0▶cy;
    ELSE             //    0100x
     IF code(7) THEN //      9 A=A+B
//      regAdd(rA,rB,rA)▶rA;
  rA(I)+rB(I)+cy▶rA(I);
  IF rA(I)>=base THEN
  ELSE
   0▶cy;
     ELSE            //      8  A=C
//      regCopy(rC,rA)▶rA;
  rC(I)▶rA(I);
  ELSE               //  00xxx
   IF code(5) THEN   //   001xx
    IF code(6) THEN  //    0011x
     IF code(7) THEN //      7 BC EX
//      rB▶rT; regCopy(rC,rB)▶rB; regCopy(rT,rC)▶rC;
  rC(I)▶T;rB(I)▶rC(I);T▶rB(I);
     ELSE            //      6 C=B
//      regCopy(rB,rC)▶rC;
  rB(I)▶rC(I);
    ELSE             //    0010x
     IF code(7) THEN //      5  AC EX
//      rA▶rT; regCopy(rC,rA)▶rA; regCopy(rT,rC)▶rC;
  rC(I)▶T;rA(I)▶rC(I);T▶rA(I);
     ELSE            //      4 B=A
//      regCopy(rA,rB)▶rB;
  rA(I)▶rB(I);
   ELSE              //   000xx
    IF code(6) THEN  //    0001x
     IF code(7) THEN //      3  AB EX
//      rA▶rT; regCopy(rB,rA)▶rA; regCopy(rT,rB)▶rB;
  rB(I)▶T;rA(I)▶rB(I);T▶rA(I);
     ELSE            //      2 C=0
//      regZero(rC)▶rC;
  0▶rC(I);
    ELSE             //    0000x
     IF code(7) THEN //      1 B=0
//      regZero(rB)▶rB;
  0▶rB(I);
     ELSE            //      0 A=0
//      regZero(rA)▶rA;
  0▶rA(I);
LOCAL opArith3() BEGIN
 code(0,3)▶J;
 CASE
  IF J=0 THEN  // pt
  IF J=1 THEN  // x
   1▶F; 3▶L;
  IF J=2 THEN  // wpt
  IF J=3 THEN  // w
   1▶F;14▶L;
  IF J=4 THEN  // pq
   pp+1▶first;pq+1▶L;
  IF J=5 THEN  // xs
   3▶F; 3▶L;
  IF J=6 THEN  // m
   4▶F; 13▶L;
  DEFAULT      // s
   14▶F; 14▶L;
 code(3,5)▶H;
 CASE
  IF H=0 THEN  // A=0
    0▶rA(I);
  IF H=1 THEN  // B=0
    0▶rB(I);
  IF H=2 THEN  // C=0
    0▶rC(I);
  IF H=3 THEN  // AB EX
    rA(I)▶T;rB(I)▶rA(I);T▶rB(I);
  IF H=4 THEN  // B=A
    rA(I)▶rB(I);
  IF H=5 THEN  // AC EX
    rA(I)▶T;rC(I)▶rA(I);T▶rC(I);
  IF H=6 THEN  // C=B
    rB(I)▶rC(I);
  IF H=7 THEN  // BC EX
  IF H=8 THEN  // A=C
    rC(I)▶rA(I);
  IF H=9 THEN  // A=A+B
    IF rA(I)>=base THEN
    ELSE
     0▶cy;
  IF H=10 THEN // A=A+C
    IF rA(I)>=base THEN
    ELSE
     0▶cy;
  IF H=11 THEN // A=A+1
   1▶cy;
    rA(I)+cy▶rA(I);
    IF rA(I)>=base THEN
    ELSE
     0▶cy;
  IF H=12 THEN // A=A-B
    IF rA(I)<0 THEN
    ELSE
     0▶cy;
  IF H=13 THEN // A=A-1
   1▶cy;
    rA(I)-cy▶rA(I);
    IF rA(I)<0 THEN
    ELSE
     0▶cy;
  IF H=14 THEN // A=A-C
    IF rA(I)<0 THEN
    ELSE
     0▶cy;
  IF H=15 THEN // C=C+C
    IF rC(I)>=base THEN
    ELSE
     0▶cy;
  IF H=16 THEN // C=A+C
    IF rC(I)>=base THEN
    ELSE
     0▶cy;
  IF H=17 THEN // C=C+1
   1▶cy;
    rC(I)+cy▶rC(I);
    IF rC(I)>=base THEN
    ELSE
     0▶cy;
  IF H=18 THEN // C=A-C
    IF rC(I)<0 THEN
    ELSE
     0▶cy;
  IF H=19 THEN // C=C-1
   1▶cy;
    rC(I)-cy▶rC(I);
    IF rC(I)<0 THEN
    ELSE
     0▶cy;
  IF H=20 THEN // C=-C
    -rC(I)-cy▶rC(I);
    IF rC(I)<0 THEN
    ELSE
     0▶cy;
  IF H=21 THEN // C=-C-1
   1▶cy;
    -rC(I)-cy▶rC(I);
    IF rC(I)<0 THEN
    ELSE
     0▶cy;
  IF H=22 THEN // ?B#0
  IF H=23 THEN // ?C#0
  IF H=24 THEN // ?A<C
    rA(I)-rC(I)-cy▶T;
    IF T<0 THEN
     1▶cy;
    ELSE
     0▶cy;
  IF H=25 THEN // ?A<B
    rA(I)-rB(I)-cy▶T;
    IF T<0 THEN
     1▶cy;
    ELSE
     0▶cy;
  IF H=26 THEN // ?A#0
  IF H=27 THEN // ?A#C
  IF H=28 THEN // ASR
    ELSE rA(I+1)▶rA(I);
  IF H=29 THEN // BSR
    ELSE rB(I+1)▶rB(I);
  IF H=30 THEN // CSR
    ELSE rC(I+1)▶rC(I);
  DEFAULT      // ASL
    ELSE rA(I-1)▶rA(I);
LOCAL opArith() BEGIN
 code(0,3)▶J;
 CASE
  IF J=0 THEN  // pt
   IFTE(ptr,pp,pq)+1▶first;first▶last;
   IF first>14 THEN 1▶first; END;
   IF last>14 THEN 1▶last; END;
  IF J=1 THEN  // x
   1▶first; 3▶last;
  IF J=2 THEN  // wpt
   1▶first;IFTE(ptr,pp,pq)+1▶last;
  IF J=3 THEN  // w
   1▶first;14▶last;
  IF J=4 THEN  // pq
   pp+1▶first;pq+1▶last;
   IF first>last THEN 14▶last; END;
  IF J=5 THEN  // xs
   3▶first; 3▶last;
  IF J=6 THEN  // m
   4▶first; 13▶last;
  DEFAULT      // s
   14▶first; 14▶last;
 code(3,5)▶H;
 CASE
  IF H=0 THEN  // A=0
   regZero(rA)▶rA; END;
  IF H=1 THEN  // B=0
   regZero(rB)▶rB; END;
  IF H=2 THEN  // C=0
   regZero(rC)▶rC; END;
   rA▶rT; regCopy(rB,rA)▶rA; regCopy(rT,rB)▶rB; END;
  IF H=4 THEN  // B=A
   regCopy(rA,rB)▶rB; END;
   rA▶rT; regCopy(rC,rA)▶rA; regCopy(rT,rC)▶rC; END;
  IF H=6 THEN  // C=B
   regCopy(rB,rC)▶rC; END;
   rB▶rT; regCopy(rC,rB)▶rB; regCopy(rT,rC)▶rC; END;
  IF H=8 THEN  // A=C
   regCopy(rC,rA)▶rA; END;
   regAdd(rA,rB,rA)▶rA; END;
   regAdd(rA,rC,rA)▶rA; END;
   1▶cy;regAdd(rA,rZ,rA)▶rA; END;
   regSub(rA,rB,rA)▶rA; END;
   1▶cy;regSub(rA,rZ,rA)▶rA; END;
   regSub(rA,rC,rA)▶rA; END;
   regAdd(rC,rC,rC)▶rC; END;
   regAdd(rA,rC,rC)▶rC; END;
   1▶cy;regAdd(rC,rZ,rC)▶rC; END;
   regSub(rA,rC,rC)▶rC; END;
   1▶cy;regSub(rC,rZ,rC)▶rC; END;
   regSub(rZ,rC,rC)▶rC; END;
   1▶cy;regSub(rZ,rC,rC)▶rC; END;
   regTestNE(rB,rZ); END;
   regTestNE(rC,rZ); END;
   regSub(rA,rC,rT); END;
   regSub(rA,rB,rT); END;
   regTestNE(rA,rZ); END;
   regTestNE(rA,rC); END;
  IF H=28 THEN // ASR
   regShiftR(rA)▶rA; END;
  IF H=29 THEN // BSR
   regShiftR(rB)▶rB; END;
  IF H=30 THEN // CSR
   regShiftR(rC)▶rC; END;
  DEFAULT      // ASL
   regShiftL(rA)▶rA;
LOCAL rst() BEGIN
 rA:=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
 rB:=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
 rC:=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
 rM:=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
 rN:=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
 rZ:=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
 rT:=[0,0,0,0,0,0,0,0,0,0,0,0,0,0];
 first:=0;
 last:=0;
 ptr:=0;
 pp:=2;
 pq:=12;
 base:=10;
 cy:=0;
LOCAL test1() BEGIN
 rst();
 FOR Z FROM 1 TO 10000 DO
  R→B(Z MOD 256,8)▶code;
  opArith();
LOCAL test2() BEGIN
 rst();
  opArith2();
LOCAL test3() BEGIN
 rst();
  opArith3();
EXPORT test42() BEGIN
 PRINT();
 PRINT(TEVAL(test1));
 PRINT(TEVAL(test2));
 PRINT(TEVAL(test3));
Binary at bug at end of page, test42-bug.zip, reboot picture there too
On a windows 10 Virtual Prime Build 2.1.14181, no problem at all
Re-flashing the firmware does not change anything.
It looks like the BREAK; command in a program, is the cause of this issue.
Go to HELP, and search for BREAK.
The example gives you a program Demo_BREAK.
When running this program, the Prime reboots.
I have had to patch several programs, not to use BREAK; and instead of that,
construct some other condition to leave a loop.
Is there a chance to get that fixed in the next firmware release?
Thanks in advance.
Martin
(05-13-2019 08:45 PM)Martin Wrote: [ -> ]It looks like the BREAK; command in a program, is the cause of this issue.
Thanks in advance.
Martin
I tried this (Demo_BREAK) again with a clean (Format C) Prime G2.
=> Same behavior => Calculator resets.
Can anybody confirm this issue, or does my Prime G2 hava a hardware issue?
Thanks in advance
Martin
(05-17-2019 07:38 PM)Martin Wrote: [ -> ]I tried this (Demo_BREAK) again with a clean (Format C) Prime G2.
Thanks in advance
Martin
Confirmed, paperclip reset required after.
Confirmed!
Paperclip reset was not necessary.
Reboots after some time.
Thanks in advance.
Martin
Thanks in advance
Martin
My G2 does the same thing. It takes a while but it resets itself with no paperclip needed.
Confirmed.
Resets itself, but no paperclip needed.
Any way to find out if this problem with BREAK is on HP's radar?
I was an early adopter of HP Prime and it was a bumpy experience at first, but eventually smoothed out. I bought a HP Prime G2 last week, updated it using connectivity kit, and it looks like I have to relive a similar experience again! Sure enough, the BREAK command crashes the calculator. Makes me wonder what else might not work quite right.
I was going to give my old HP Prime to a student, but now I'm apprehensive and so will wait to see how HP deals with this.
(10-15-2019 03:49 AM)mbeddo Wrote: [ -> ]Any way to find out if this problem with BREAK is on HP's radar?
Yes.
(10-15-2019 05:18 AM)Tim Wessman Wrote: [ -> ]
Yes.
Thanks Tim.
I bought my G2 about a week ago (October 7).
In my case, I don't have a BREAK in my code but WAIT/ON seems implicated.
Normally (G1) this code draws a picture and waits for a key press and returns the same.
Typically I'll press the ON key and get '46' in an alert box.
However, as I duplicated this sequence I periodically the get three second reset warning (no keycode) and then the Prime resets.
I hope this helps someone who knows what is happening.
EXPORT ORBITDGM()
RECT();
FOR C FROM −2 TO 0.25 STEP 0.00625 DO
X:=0;
M:=142*(C+2);
FOR I FROM 2 TO 100 DO
X:=X*X+C;
IF I < 30 THEN
CONTINUE;
N:=60*(2-X);
PIXON_P(M,N,#FF00FF);
WAIT;
Thanks,
Steve Brenton
