01-30-2019, 01:33 PM
An extract from Computation of Semi-Infinite Integrals on a Programmable Hand Calculator, Comp. & Maths with Appls Vol 3. pp 191-196.
Abstract-Two functions arising in physical applications which are defined by complicated integral expressions are evaluated on a programmable hand calculator: The method is based on a quadrature rule using nodes in a geometric progression. This rule is particularly suitable for use on a hand calculator because the weights and nodes are easily generated during the calculations.
INTRODUCTION
The hand calculator has developed into an instrument which can be used for calculations of considerable complexity. Surveys of the use of such calculators are given by Smith[l] and by Killingbeck[2], but it is difficult to keep up with such a rapidly developing field. This note reports on the use of a HP 65 programmable calculator to evaluate two functions defined by formidable integral expressions.
BEST!
SlideRule
INTRODUCTION
BEST!
SlideRule
