Full Version: (12C Platinum) Flip Virtual Coin
This program allows you to flip a virtual coin by giving how many time you like to flip a coil then tell you how many time it was Head.
Procedure: FIX 0 with [ALG] Mode
1.Input Seed at Register 2
2. Input how many flips then [R/S]
3. Answer: number of Head
4. Continue STEP 2.
Example:
Seed: .104056 [STO] 2
Number of flips: 10 [R/S]
Result: 6 // With 10 flips it is 6 time with head result.
Program: ALG mode
STO 0
CLx
STO 1
RCL 0
X=0
GTO 023
1
STO-0
997 x RCL 2 =
FRAC
STO 2
x 2 =
INTG
STO+1
GTO 004
RCL 1
Remark:
The computation speed depending on how large the number of flip.
12C Platinum App will run much faster.
Gamo
(12-17-2018 07:09 AM)Gamo Wrote: [ -> ]This program allows you to flip a virtual coin by giving how many time you like to flip a coil then tell you how many time it was Head.
The random number generator produces either a 0 or a 1. So you do not have to check whether this is zero or not...
X=0
GTO 004
1
STO+1
GTO 004
...instead you can simply add this 0 or 1 to register 1. ;-)
Just replace the above code section with a simple STO+1.
And change GTO 026 into GTO 023 of course.
(12-17-2018 07:09 AM)Gamo Wrote: [ -> ]The computation speed depending on how large the number of flip.
For a large number of n coin flips the head (and tail) count approaches n/2.
So you may use the following program for very large n instead:
รท
2
GTO 00
Dieter
Dieter
Thanks for the review now changed using your recommendation.
Gamo Smile
