Today I noticed my partner pull out an old Casio fx-29 calculator that I didn't know she had!
Here is a photo I found on a website of this calculator.
Needless to say I immediately had a play.
I liked the keyboard feel and the glowing blue display. The time it took to calculate SIN was longer than I thought - about a second. I'm sure HP was never that slow!?
Then I hit the main stumbling block - how to do x^y. I can't find a manual online and not sure how to enter a second number before pressing the x^y key. Can anyone please give me a hint on how to drive this thing?
P.S. Relatedly, found this
interesting article about operator precedence in Casio's calculator design history.
(12-05-2018 07:29 AM)tcab Wrote: [ -> ]Today I noticed my partner pull out an old Casio fx-29 calculator that I didn't know she had!
P.S. Relatedly, found this interesting article about operator precedence in Casio's calculator design history.
Isn't it
[x] x^y [y] = ?
I have one at home, could check this evening...
Yes that seems to work - thanks. What confused me was when I enter a number then hit the x^y key the calculator does something to the number and changes it. E.g. "2 x^y" gives me 0.6931 (confusing!) and when I keep going and hit "4 =" then finally I get the answer 16.
What is 0.6931 supposed to mean? Seems you have to ignore the intermediate number and just press on with the key sequence. Entering different x values followed by x^y give different "intermediate" numbers. Very confusing.
0.6931 is approximately ln 2
Fascinating. I just crunched a series of numbers on the Casio fx-29, and indeed, pressing NUM x^y is the same as pressing NUM ln.
I wonder what the relationship between ln and x^y is, such that the calculator feels the need to do this...
(12-05-2018 08:53 AM)tcab Wrote: [ -> ]I wonder what the relationship between ln and x^y is, such that the calculator feels the need to do this...
Once you have implemented the algorithms for ln(x) and e^x, you can easily get x^y as x^y = e^(ln(x)*y)
I never had a fx-29, but I'm pretty sure I had a fx-39 at some point during my school years. I don't remember seeing any strange behaviour for the x^y key so I guess they changed it between the fx-29 and fx-39, although I no longer have the calculator to check.
(12-05-2018 01:00 PM)ijabbott Wrote: [ -> ]I never had a fx-29, but I'm pretty sure I had a fx-39 at some point during my school years.
Any AOS calculator that had [X<>Y] key cannot assume x^y = exp(y * ln(x)).
It had to wait until [=] key is pressed (or other operators, say + - x /)
So, based on googled fx-39 pictures, you will not see ln(x) intermediates.
Quote:The time it took to calculate SIN was longer than I thought - about a second. I'm sure HP was never that slow!?
Interesting no factorial function, probably as this was an entry level Scientific, however I believe this was on the FX-501P (likely +1 years, 1979) but not the later fx-29 equivalent (likely the FX-80 +1-2 years).
69! was very slow on the early TI's that had the function, likely the Casio and HP's as well.
(12-05-2018 02:31 PM)Albert Chan Wrote: [ -> ] (12-05-2018 01:00 PM)ijabbott Wrote: [ -> ]I never had a fx-29, but I'm pretty sure I had a fx-39 at some point during my school years.
Actually, it might have been an fx-110 I had, which was similar to the fx-39, but with extra digits on the display, and the angle/sd mode switch in a different place. EDIT: Probably not though, because I don't remember mine having a dB conversion function. I've not seen a dedicated dB conversion function on a calculator before!
