I have the following sample program in the emulator, latest ROM.[/quote]
PHP Code:
EXPORT FOO()
LOCAL i, p;
PRINT();
i := 0;
IFERR
WHILE i < 3 DO
p := CAS.part("sin(45)", i);
PRINT(p);
i := i + 1;
THEN
PRINT("Error at part "+i);
ELSE
PRINT("No error");
RETURN 1;
When I run it I get the following on the terminal:
Quote:sin
45
part(sin(45),i_,i_)
Error: Bad Argument Value
No error
As you can see from the messages, the IFERR error handler didn't trap the CAS error. Is there another 'official' way to do this?
You can trap CAS errors in CAS programs.
If your expected result will never be a string, testing for a string after could also work for you I think.
Thanks Tim.
Actually it is the part() function that I want to trap and it can return a string legitimately.
After reading Parisse's suggestion, it occurred to me that rather than try and trap the error from part() in my main code, I could just use a separate #cas...#end bracketed function which calls part() with 1, 2, 3, .. etc until it fails and then return the max value to use as the loop upper bound in my main code with no worries about errors.
(12-01-2018 02:48 PM)BruceH Wrote: [ -> ]separate #cas...#end bracketed function which calls part() with 1, 2, 3, .. etc until it fails and then return the max value
That look like the function len() ...
One thing to remember, if you have a PPL program with an IFERR statement, there is an excellent chance that the next CAS command you use will crash your program.
Example:
EXPORT Demo_IFERR()
LOCAL m;
RECT_P();
TEXTOUT_P("Press ON to generate an error ...",G0,5,5,4);
REPEAT
IFERR m:=WAIT(-1); THEN
m:=4;
TEXTOUT_P("Error triggered ...",G0,5,25,4);
ELSE
TEXTOUT_P("Error avoided ...",G0,5,25,4);
UNTIL TYPE(m)==0;
TEXTOUT_P("Program still running ...",G0,5,45,4);
WAIT(1);
MSGBOX(stddev({0.01,0.02,-0.015,0.005}));
You can force the error in the program above by pressing the ON key on the keyboard. If you do so, the crash/error happens when the "stddev" command is encountered. This is true for all CAS commands. Has caught me a few times now, and difficult to debug if you're not aware of this. I have written multiple substitute routines to get around the need for CAS commands as a result.
(12-01-2018 03:41 PM)Albert Chan Wrote: [ -> ] (12-01-2018 02:48 PM)BruceH Wrote: [ -> ]separate #cas...#end bracketed function which calls part() with 1, 2, 3, .. etc until it fails and then return the max value
Thanks Albert - length() is indeed the function that I'm after. I had previously tried DIM but it doesn't work for all expressions. I'd also tried SIZE with no luck, but overlooked length.
And thanks also to Jacob for the warning - I had no idea I was going to open a can of worms. :-)
