Are these rare? I have been looking for one for awhile with no luck... did see one on eBay about a year ago but was foolish and didn't purchase but it was I believe around $100. Any pointers?
Thanks!
Yes. They are rare and something to know: these cards run only in a
SX (not the GX).
Also, it seems to be more a "simulator" than a real emulator.
A better alternative could be
HP41X.
Oh, I suspected it was the SX only, thanks for confirming!
If only the SX had a decent display.... or it was easy to swap with the later Black GX's.
Small correction: There is a version for the GX, but only ONE unique card (as I know).....
Some pointer to the HP 82210A : HP 41CV Emulator Application Card for the HP 48SX
(11-08-2018 07:33 PM)cgh Wrote: [ -> ]Also, it seems to be more a "simulator" than a real emulator.
As written before, the Zengrange "HP41CV Emulator" Card is a simulator on the UI side, but it incarnates a FOCAL execution engine which is compatible to the real HP-41 and the real HP-42S. IOW the FOCAL bytecode is the same on all three mentionned platforms.
(11-08-2018 10:48 PM)HP-Collection Wrote: [ -> ]Small correction: There is a version for the GX, but only ONE unique card (as I know).....
Did I mention that there is a new GX version which has a much faster UI and translates even longer FOCAL program texts into FXE bytecode within seconds instead of minutes?
Thanks for these detailed notes Raymond. Was the GX version marketed under the same model number and how can one tell which version will work on the GX (or is it both SX and GX)?
I have a card that reports "0E" for the response to the VERS41 command in the Ctl41 Library. Seems to be SX only. Copyright on the card is Zengrange, 1990.
The GX version was never marketed through HP, and that GX version I mentionned was not made by Zengrange nor by the original author of the Zengrange code.
The GX version I'm talking about is a single library, has a much faster UI than the Zengrange version, doesn't use absolute addressing, and thus can be stored anywhere in port 0 or 1 .
Hi Raymond,
So how can we obtain the GX version (just asking a leading question)?
Already have the card for the SX version but would be interested in the GX version as an alternative.
Thanks,
Michael
Gosh, I am several thousand miles away from home and just cannot verify what my 41 emulator card version is...
Giancarlo
(11-13-2018 12:16 PM)Giancarlo Wrote: [ -> ]Gosh, I am several thousand miles away from home and just cannot verify what my 41 emulator card version is...
Giancarlo
If it's on a card it is the SX version.
(11-13-2018 09:45 AM)Raymond Del Tondo Wrote: [ -> ]The GX version was never marketed through HP, and that GX version I mentionned was not made by Zengrange nor by the original author of the Zengrange code.
I agree, I'd like to see this version if it could be shared. The faster UI plus extra GX speed should make it more natural to use.
Did someone hack the original version with GX and UI speedup changes or was this a complete re-write? Either way, seems like quite an extraordinary accomplishment, the author was clearly quite skilled.
(11-13-2018 02:11 PM)rprosperi Wrote: [ -> ]Did someone hack the original version with GX and UI speedup changes or was this a complete re-write? Either way, seems like quite an extraordinary accomplishment, the author was clearly quite skilled.
I wonder who he is... ;)
(11-13-2018 03:24 AM)rprosperi Wrote: [ -> ]I have a card that reports "0E" for the response to the VERS41 command in the Ctl41 Library. Seems to be SX only. Copyright on the card is Zengrange, 1990.
I just received a 48SX with a HP41 Emulator card inside. It was not advertised as such but I spotted the emulator overlay on the keyboard.
The VERS41 reports "0A" for the emulator card, and the 48SX rom version is D (s/n 3019A)
The entire string returned by VERS41 is:
0A
Copyright 1990
Zengrange Inc.
900928 0133
Design & code:
FCW,IW,RWJ,DRC
Manual:WACM-J,MHJ,TJW
for Terra Pacific
Help:TWB,CB,SB,DKB,
JAD,DLE,SRL,VKL,RM,
RJN,CP,GP,GS,JS,BGS,
BAS,ELV,WCW,RSW,DY,RY
Patience:SHC,HG,PK
900928 0133 seems to be the date and time of the rev 0A release, which is aligned with the manual Edition 1 October 1990.
(11-24-2018 09:14 AM)Didier Lachieze Wrote: [ -> ]Manual:WACM-J,MHJ,TJW
WACM-J = Wlodek A.C. Mier-Jedrzejowicz
(11-24-2018 02:20 PM)J-F Garnier Wrote: [ -> ] (11-24-2018 09:14 AM)Didier Lachieze Wrote: [ -> ]Manual:WACM-J,MHJ,TJW
I am certain that "FCW" is Frank Wales.
Jake
