LOCAL CRID:="SortL API V0.7 © 2019 StephenG1CMZ";
LOCAL MORETEXT:="A collection of Sort(List) routines brought to you by StephenG1CMZ,\n with some from the forum.";
LOCAL MN:="SortL.";//Name
//Dictionary
//ITEM: an element of a list (or a value which could be in a list)
//ITEMS: a list of 0..n ITEMs
//KEYLST: sorting this sorts your other list(s)
//LST: a list
//LOL or LSTS: List Of lists EG {{1,2},{3,4}} (just {{1,2}} may be OK)
//REVERSE: reverses a list (i.e. to reverse-Sort do REVERSE(SORT()) )
//All lists may be empty (except: SortN)
//IMPORT({PPLX}); //TYPE
//IMPORT({List}); //Required
//Some exportables (ex) omitted to minimise global impact
//Customise
EXPORT SortableNumericTypes:={TYPEREAL,TYPEINT};
LOCAL UNK0:=0;//EMPTY IS UNKNOWN,DEFAULT FALSE
LOCAL UNK1:=1;//EMPTY IS UNKNOWN,DEFAULT TRUE
//LOCAL SL:=1;
//NB To test: sort >1 item
//End Custom
//Forward
IsSortablePortable(LST);
SortByKey(SORTL,Keynum);
SortLST(LST);
SortN(LST,NN);
LOCAL NL:="\n";
//ERR
LOCAL ListErrK:=1;
LOCAL PyErrK:=3;
LOCAL ERRKIND:={"","Error","","Py Error"};
EXPORT EL:={
"(/0) DivideBy0",
"IndexOutofBoundsException",
"ListIsEmptyError",
"ListIsFullError",
"ListSortError",
"ListStatisticsError",
"ItemNotFoundError",
"ValueError"
//ERRNO IS ARBITRARY:INDEXES ERRLST
EXPORT DivBy0Error:=1;
LOCAL IndexOutOfBoundsException:=2;//List J
EXPORT ListIsEmptyError:=3;
LOCAL ListIsFullError:=4;//UNUSED YET
LOCAL SortError:=5;
EXPORT ListStatisticsError:=6;
EXPORT ItemNotFoundError:=7;//List Py
EXPORT ValueError:=8; // Py
EXPORT ABOUT()
MSGBOX(CRID);
MSGBOX(MORETEXT);
TBD()
MSGBOX(MN+"TBD");
IsSortable(LST) //ex
//For now use Portable
//Later: as native SORT
RETURN IsSortablePortable(LST);
EXPORT IsSortableNative(LST)
//Checks whether the contents of LST are natively sortable
//Returns 1 TYPESTR only
//Returns 1 SortableNumeric
//NB Lists and keys can be sorted but lists alone no
LOCAL TP;
IF SIZE(LST) THEN
TP:=TYPE(LST(1));
CASE
IF TP==TYPESTR THEN
RETURN ListIsTYPE(LST,TYPESTR);
IF POS(SortableNumericTypes,TP) THEN
RETURN ListIsTYPE(LST,SortableNumericTypes);
DEFAULT
RETURN 0;//UNSORTABLE
END;//CASE
RETURN UNK1;//EMPTY INDETERMINATE
EXPORT IsSortablePortable(LST)
//0.Is parameter a list
//1.Is TYPE of contents OF ORDERABLE DATA
//2.Is SORTL implemented on that type yet
//NOTE:
//IsSORTABLE({Real})=1 AND IsSORTABLE({INT})=1 AND IsSORTABLE({string})=1 but
//do not assume SORT({mixed}) will deliver your expectations
//NB The current algorithm reports {1,"4"} as sortable
//But native sort wont
//The Portable variant assumes strings and numerics are sortable.
LOCAL SortableTypes:=CONCAT(SortableNumericTypes,TYPESTR);
IF TYPE(LST)==TYPELST THEN
IF SIZE(LST) THEN
RETURN ListIsTYPE(LST,SortableTypes);
RETURN UNK0;//EMPTY
RETURN 0;//NOT LIST:CANNOT BE SORTED
IsSortedEQ(LST) //EX
//Tells whether a list is sorted...inefficiently
//By sorting it and checking equality
//(Useful for testing)
ListANS:=SortLST(LST);
RETURN EQ(ListANS,LST);
EXPORT IsSorted(LST)
//Looping until 1st descending will/may be quicker TBD
RETURN IsSortedEQ(LST);
EXPORT ReverseLOL(LSTS)
//Reverse a list of lists
//EG {{1,2},{3,4}} -> {{2,1},{4,3}}
//NONRECURSIVE:2ND LEVEL LISTS ONLY
//ALL LISTS MUST BE REVERSIBLE
LOCAL II;
ListANS:={};
IF SIZE(LSTS) THEN
//REVERSE EACH LST
FOR II FROM 1 TO SIZE(LSTS) DO
ListANS(II):=REVERSE(LSTS(II));
END;//FOR
RETURN ListANS;
EXPORT SortByABS(LST)
//Return LST SORTED BY ABS VALUE
//Note that #integers return floats
//ALT: USE SortByFun(LST,ABS(LST))
//SortByABS is quicker
LOCAL TMP:={};
IF SIZE(LST) THEN
TMP:=SortN({ABS(LST),SIGN(LST)},1);
RETURN TMP(1)*TMP(2);
RETURN {};
EXPORT SortByCounts(LST)
//Returns {LSTV,LSTF} sorted by frequency of occurrence
//EG {{1,2,3},{10,30,20}} -> {{2,3,1},{10,20,30}}
//Return {SORTEDL,SORTEDCOUNTS}
ListANS:=ListCOUNTS(LST);//To omit this step, use SortByKey directly
RETURN SortByKey(ListANS,2);
EXPORT SortByFun(LST,SortFun)
//Sort using SortFun as your sort function
//EG SortByFun(LST,ABS(LST)) //BUT SortByABS is faster (Again #integers return floats)
//EG SortByFun(LST,MYSORTFUN(LST[,ITEM]))
//Note: The function name alone is not sufficient
//See https://www.hpmuseum.org/forum/thread-6179.html for alternative CAS syntaxes
//ALT: Use Pysort("fun")
LOCAL SORTORDER;
LOCAL SORTED:={{},{}};//GUARD EMPTY LIST
IF SIZE(LST) THEN
SORTORDER:=SortFun;
SORTED:=SortN({LST,SORTORDER},2);
RETURN SORTED(1); //TO SEE THE SORT ORDER INSTEAD:2
EXPORT SortByIndex(LST,XLST)
//Return the indexes from LST specified by XLST
//A partial list is valid, as are repetitions
//An entry in XLST > SIZE(LST) could be checked 1st
LOCAL II;
LOCAL TMP:={0};
IF SIZE(LST) AND SIZE(XLST) THEN
//To improve speed omit test
//Hint: Check this 1st before calling this routine multiple times
// when you have several similar lists
//TMP:=MAKELIST((XLST(II)>SIZE(LST)),II,1,SIZE(XLST));//OPTIONAL TEST
//IF ΣLIST(TMP)THEN
// RAISE(MN+"SortByIndex",EL,SortError,ΣLIST(TMP),ListErrK);
//ELSE
RETURN MAKELIST(LST(XLST(II)),II,1,SIZE(XLST));
//END;
RETURN {};
EXPORT SortByKeyLST(LST,KEYLST)
//Sort 1 LST using KEYLST.
//KEYLST will be sorted to determine how to sort LST
//LST must be sortable. LOL will fail.
//Cf: SortByKey({LST},KEYLST)
LOCAL TMP;
IF SIZE(LST) AND SIZE(KEYLST) THEN
TMP:=SortN({LST,KEYLST},2);
//Make Customisable?
//One will match SortByKey({LST},KEYLST)
RETURN TMP; // {SORTEDLST,SORTEDKEYLST}
RETURN TMP(1); // SORTEDLST
RETURN {};
SortByKeyLSTS(LSTS,KEYLST)
//Sort LSTS using KEYLST to order.
//Return: SORTEDLSTS
//If KEYLST exists within LSTS use: SortByKeyNUM(LSTS,N)
LOCAL TMP;
IF SIZE(LSTS) AND SIZE(KEYLST) THEN
LSTS(0):=KEYLST;
TMP:= SortN(LSTS,SIZE(LSTS));
RETURN ListBEFORE(TMP,SIZE(TMP));
RETURN {};
SortByKeyNUM(LSTS,Keynum)
//LSTS is {LSTV,LSTF} as returned by
//ListCOUNTS(LST);
//but additional fields are allowed
//Returns {SORTED LSTS} sorted by sort key criteria
//EG ({{1,2,3},{10,30,20}},2) -> {{2,3,1},{10,20,30}}
IF 0<Keynum≤SIZE(LSTS) THEN
IF SIZE(LSTS(1)) AND SIZE(LSTS(Keynum)) THEN
//Strictly all are lists of same size
RETURN SortN(LSTS,Keynum);
//Potential errors:not all checked
//List small, not containing lists, key out of range, key list unsortable
RAISE(MN+"SortByKey",EL,SortError,Keynum,ListErrK);
RETURN {};
//To reverse sequence call ReverseLOLS()
EXPORT SortByKey(LSTS,KEY)
//Sort LSTS by KEY
//EG (LSTS,2) OR (LSTS,{6,5}) WHERE LSTS={{1,2},{3,4}}
CASE
IF TYPE(KEY)==TYPELST THEN SortByKeyLSTS(LSTS,KEY) END;
DEFAULT //numeric KEY param
SortByKeyNUM(LSTS,KEY);
EXPORT SortFromItem(LST,ITEM)
//Return simple sort distance
//Return LST SORTED BY NUMERICAL ABS VALUE FROM ITEM
//=SortFromItems(LST,{ITEM})
//ALT: USE SortByFun(LST,MYSORTFUN(LST...))
LOCAL TMP:={};
IF SIZE(LST) THEN
TMP:=SortByFun(LST,ABS(LST-ITEM));
RETURN TMP;
EXPORT SortFromItems(LST,ITEMS)
//Sort by min sort distance from a list of items
//#integers return floats
//EMPTY LISTS: RETURN EMPTY LIST
// (or: perhaps empty ITEMS should simply SORT(LST)?)
LOCAL DX:={};
LOCAL TMP:={{},{}};
LOCAL II;
IF SIZE(LST) AND SIZE(ITEMS) THEN
//IF SIZE(ITEMS)==1 THEN //OPTIONAL OPTIMISE
// RETURN SortFromItem(LST,ITEMS(1));
//END;
//DX:=sort distance from nearest ITEM
DX:=MAKELIST(MIN(ABS(LST(II)-ITEMS)),II,1,SIZE(LST));
TMP:=SortN({LST,DX},2);
RETURN TMP(1);
SortLST(LST) //ex
//This implementation uses native SORT
//It is convenient to export when comparing with other sorts
IF TYPE(LST)≠TYPELST THEN
RAISE(MN+"SortLST",EL,SortError,"",ListErrK);
RETURN {};
RETURN SORT(LST);
EXPORT SortN(list,n)
// From http://www.hpmuseum.org/forum/thread-6179.html?highlight=sort+two+lists
//Call via ListSORTBYKEY to guard parameters...or call directly with good inputs
LOCAL li,ma;
ma:=list2mat(list) ;
li:=SORT(MAKELIST(mat2list(col(ma,I)),I,1,colDim(ma)),n);
RETURN MAKELIST(mat2list(col(list2mat(li),I)),I,1,rowDim(ma));
//For example:
//SORTN({{3,2,1},{15,20,18}},1);// -> {{1,2,3},{18,20,15}}
//SORTN({{3,2,1},{15,20,18},{32,35,27}},1);// -> {{1,2,3},{18,20,15},{27,35,32}}
SortsVERSION() //ex
RETURN CRID;
Pyreverse(LST) //ex
//Python analogue
RETURN REVERSE(LST);
EXPORT Pysort(LST,KeyFunc,RReverse)
//Python analogue SORT
//PyOpt KeyFunc: STRING EG "ABS" (NULL=NONE)
//PyOpt PRReverse BOOL
//ALT: Use SortByFun(LST,Fun(LST...))
//Note: The Py syntax is optional fun without strings
//Using strings here allows optional null string to be handled
//The alt SortByFun avoids strings but requires a function
LOCAL TMP;
IF KeyFunc=="" THEN
ListANS:=SORT(LST);
RETURN IFTE(RReverse,Pyreverse(ListANS),ListANS);
TMP:=EXPR(KeyFunc+"(LST)");
ListANS:=SortN({LST,TMP},2);
RETURN IFTE(RReverse,Pyreverse(ListANS(1)),ListANS(1));
ListPuzzles() //EX
//SEE http://www.hpmuseum.org/forum/thread-8209.html?highlight=challenge
LOCAL VR;
LOCAL LST:=MAKELIST("",VR,1,5);//40
LST(2):="31. ListOCCURRENCESWITHSORT";
CHOOSE(VR,MN+"Puzzles (See thread)",LST);
EXPORT SortSeeAlso () //ex
LOCAL KK;
LOCAL CatFuns:={
"REVERSE",
"reverse",
"revlist (slower)",
"SORT",
"sort"
//Just Listed as a reminder:not Selectable
CHOOSE(KK,MN+" Relevant Cat Functions",CatFuns)
EXAMPLESORTFROM()
//EG DISTANCE FROM FIRST AID POSTS AT 5 mile intervals along a half marathon
LOCAL ITEMS:={0,5,10};//FIRST AID POSTS
//LOCAL LST:={10,5,−20,−5,20,−10};
LOCAL LST:={1,2,3,4,5,6,7,8,9,10,11,12,13};
LOCAL OUTLST;
PRINT();
PRINT(OUTLST:=SortFromItems(LST,ITEMS));//CLOSEST LISTED FIRST
EXPORT SortsExamples() //ex
//In real use, use XXX:=Sort...()
LOCAL LL:={1,2,3,4,5,6,7,8,9};
PRINT();
PRINT(SortsVERSION);
PRINT("Is");
PRINT(IsSortable(0));
PRINT(IsSortable({}));
PRINT(IsSortable(LL));
PRINT(IsSortablePortable(LL));
PRINT(IsSorted(LL));
PRINT(IsSortedEQ(LL));
PRINT("Reverse");
PRINT(ReverseLOL({{1,2},{3,4},{5,6}}));
PRINT("Sort");
//SortByABS
PRINT(SortByABS({1,2,3,−2})); // -> {1,2,−2,3}
//SortByCounts
PRINT(SortByCounts({1,2,3,2,3,3})); // -> {{1,2,3},{1,2,3}}
//SortByKey
PRINT(SortByKeyNUM({{1,2,3},{10,30,20}},2)); //-> {{1,3,2},{10,20,30}}
PRINT(SortByKeyNUM({{1,2,3},{1,22,3}},2));
PRINT(ReverseLOL(SortByKeyNUM({{1,2,3},{1,22,3}},2)));
//SortL
PRINT(SortLST(LL));
//SortN
PRINT(SortN({{3,2,1},{15,20,18}},1));// -> {{1,2,3},{18,20,15}}
PRINT(SortN({{3,2,1},{15,20,18},{32,35,27}},1));// -> {{1,2,3},{18,20,15},{27,35,32}}
PRINT("Py");
PRINT(Pyreverse({1,2,3}));
PRINT(Pysort({1,22,3},"",0));
PRINT(Pysort({1,22,3},"ABS",0));
PRINT("Exampled");
//RETURN 0;
EXPORT SORTL()
LOCAL LST:={};
ABOUT();
//SortExamples();
