09-06-2018, 11:00 AM
Program to check if the given two numbers is to the power of other.
Procedure:
n1 [ENTER] n2 [R/S] or n2 [ENTER] n1 [R/S]
Display 0 // Two numbers is not the power of the other
Display 1 // Two numbers is the power of the other
When display show 1 user can recheck for base integer, power integer and X^Y result
Display 1
Rv // Base Integer
Rv // Power Interger
Rv // X^Y Answer
Example:
Is base 5 power to 625 ?
5 [ENTER] 625 [R/S] // Number input can switch around 625 [ENTER] 5 [R/S]
1 Display // True
Rv Display 5 // Base Number
Rv Display 4 // Power Number
Rv Display 625 // X^Y result
Is base 101 power to 104060401 ?
101 [ENTER] 104060401 [R/S]
1 Display // True
Rv Display 101 // Base Number
Rv Display 104060401 // X^Y result
Is base 2 power to 4099 ?
4099 [ENTER] 2 [R/S]
0 Display // Two numbers not a power to other
Program:
Gamo
Procedure:
Display 1
Rv // Base Integer
Rv // X^Y Answer
Example:
1 Display // True
1 Display // True
Program:
01 X≤Y
02 X<>Y
03 X<>Y
04 STO 1
05 X<>Y
06 STO 2
07 CLx
08 STO 3
09 1
10 STO+3
11 RCL 3
12 RCL 1
13 X<>Y
14 Y^X
15 STO 4
16 RCL 2
17 X≤Y
18 GTO 20
19 GTO 09
20 RCL 4
21 RCL 2
22 -
23 X=0
24 GTO 27
25 0
26 GTO 00
27 RCL 2
28 RCL 3
29 RCL 1
30 1
31 GTO 00
Gamo
