Today received my new G2 HP Prime from derekenwinkel.nl (Klaas Kuperus).
HP Product: 2AP18AA # B1S.
Hardware version: D.
CAS 1.4.9
Operating System: V2.060.650.
This afternoon I have updated it to version 2.0.0.13865. This went smoothly.
It's faster than my old HW-A, I've noticed this by reallocating the app icons at Application Library.
I have not done any speed measurements.
Of course the G2 has the high contrast keys. For the rest the same appearance.
I’m very happy with my new G2 HP Prime!
(08-10-2018 02:12 PM)Dirk.nl Wrote: [ -> ]Hello,
CAS 1.4.9
Their webpage still says Manufacturer code G8X92AA # B1S.
Do they ship only the new G2 or are they just shipping whatever they have on hand at the moment?
grsbanks and toml_12953.
If you order a HP Prime at derekenwinkel.nl then I think you get a HP Prime V2 delivered. Calling or e-mailing with Klaas seems to me the best. I doubt whether there are enough G2’s, they have only been introduced in Europe yet. As far as the color of the HP Prime photo is concerned; will not be updated yet, I think.
Cristobal.
Dark theme makes no difference as far as I can see.
With mem - info is indicated:
Memory: 245.99 MB
Storage: 460.73 MB
I was surprised, what a lot of memory!
(08-10-2018 08:05 PM)Dirk.nl Wrote: [ -> ]With mem - info is indicated:
Memory: 245.99 MB
Storage: 460.73 MB
Are these the correct figures? Because this combined with all the info I've seen here so far sounds more like a completely new and different calculator that just happens to look exactly like the previous model rather than a normal hardware revision of an existing product.
Hi Jean,
The size of the memories are those that I see with Mem-info.
I do not know if the shots are correct, could be a mistake in the software, but I do not think so for now.
The appearance is the same; same screen dimensions, same housing, same keys. In other words; looks the same! Inside the hardware will be different, I think. Insiders can tell that better.
Hello Stevetuc,
I performed the savage benchmark test on my HW-A and HW-D (G2) Prime.
HW_A between 548 and 567 mS
HW_D between 195 and 204 mS
On both machines A = 2500.00005268
See the program below.
Math7,
I have a bad camera, but the exterior is exactly that of HW-C with the improved color scheme!
EXPORT SAVAGE()
A:=1;
B:=TICKS;
FOR I FROM 1 TO 2499 DO
A:=TAN(ATAN(EXP(LN(√(A+1)^2))));
B:=TICKS-B;
Note.
I do not want to open the Prime to look at the type numbers of the CPU and memories.
The lion battery is 2000mAh (7.4 Wh) instead of 1500mAh.
(08-12-2018 10:25 AM)Dirk.nl Wrote: [ -> ]Hello Stevetuc,
Math7,
EXPORT SAVAGE()
A:=1;
B:=TICKS;
B:=TICKS-B;
Note.
Math7,
EXPORT SAVAGE()
A:=1;
B:=TICKS;
B:=TICKS-B;
Note.
My implementation of the Savage benchmark gives a different constant - but it also provides an exact CAS version too, allowing CAS performance to be evaluated too. http://www.hpmuseum.org/forum/thread-9626.html
But I have no hardware to report results on
(08-12-2018 10:25 AM)Dirk.nl Wrote: [ -> ]I have a bad camera, but the exterior is exactly that of HW-C with the improved color scheme!
Even the "regulatory block" on the back, which says "BC01" on G1 Primes? It would be nice if the G2 says "BC02" on the back, thereby making it easy to tell the G1 and G2 apart without turning them on.
