08-01-2018, 05:33 PM
08-02-2018, 05:52 AM
"View Today's Post" also not work the link show broken URL.
Thank You
Gamo
Thank You
Gamo
08-02-2018, 02:22 PM
Search, View New, View Today all should be working now.
08-02-2018, 02:50 PM
Thank You
Now all work
Gamo
Now all work
Gamo
08-02-2018, 02:58 PM
(08-02-2018 02:22 PM)Dave Hicks Wrote: [ -> ]Search, View New, View Today all should be working now.
And quote too!
Thanks Dave.
08-02-2018, 08:36 PM
Thanks Dave!
BTW, what was going on? Quite strange for a mybb site to be half-working like that.
08-04-2018, 02:34 AM
It was actually a site/host change that needed to be worked around.
“I know engineers. They love to change things.” - Leonard McCoy
08-04-2018, 12:55 PM
(08-04-2018 02:34 AM)Dave Hicks Wrote: [ -> ]It was actually a site/host change that needed to be worked around.
Thanks Dave.
And btw, one of the best ST quotes ever!
08-04-2018, 05:44 PM
It not only should work, it really does :-). Many thanks.
09-01-2018, 02:13 PM
It is now broken on Android.
Searching for "resistor" in the HP Prime software library,, the forum selected didn't change.
It returned dozens of threads - I would be surprised if they all contained that word.
09-01-2018, 09:22 PM
If the dozens of threads you are seeing are in more than just the Prime Software forum, then you need to deselect "Search all open forums" in your search. On Android/Chrome, select boxes are multi-choice by default. On Keyboarded computers, the same select boxes are usually single-choice by default but you can override that ctrl, shift, command etc. keys. I don't do that much on Android, but checking a couple of forums that I could think of, all acted the same way where just touching one forum selected that forum in addition to the default of all forums.
09-01-2018, 11:30 PM
Thank you, that explains the Selected forum not changing.
I'm sure that used to work without deselecting "All".
