Full Version: Touch Periodic Table
Pages: 1 2
Here is an improved version of Mickaël Nicotera's Periodic Table program for the HP Prime.
How to install the program in the emulator:
1.- unzip the hpprgm file
2.- copy the hpprgm file in :
C:\Users\[your user name]\AppData\Roaming\HP_Prime (in Windows 7 or 8)
or
C:\Documents and Settings\[Owner]\Application Data\HP_Prime (in Windows XP)
3.- Run the emulator and then [Shift]+[1]. The program should be in the program catalog.
There are several ways to transfer the program to your calculator. For example, connect your Prime to the computer and use the connect option of the calculator
Fixed - Thank you Han for detecting these bugs
1) Select an element, press ENTER. Then press HOME. Now, scroll the screen and press ENTER (don't choose a new element). --> nothing happens - FIXED
2) Select an element, press ENTER. Then press HOME. Now, choose to menu option. Press OK when given the prompt and return to the table. Now press ENTER. --> nothing happens - FIXED
Improvements
1.- Now the text is not affected by the color schema - Thanks Orcinus
2.- The selected element is now showed using FILLPOLY with alpha blending, as suggested by Han. - Thanks to Han, and also Eddie for his video on how to use FILLPOLY.
To do
1- Better handling of mouse and keyboard events as suggested by Han. I have not figured out yet how to implement the scrolling using WAIT(-1)
I will keep the program updated here. The main credits go to Nic who is the author of the program.
Miguel
May I suggest to look at my software totally different from the one developed by Nic.(I use spreadsheets)....
Download it at the Programming with Speadsheets Post.
It offers a simultaneous navigation by touch/mouse and joy stick OR by initials (just key in the initial letter of the element) in English/Spanish/French (in the same spreadsheet).
I you have any modification to bring ....
(04-18-2014 01:44 PM)Miguel Toro Wrote: [ -> ]Hello,
or
Improvements
To do
Miguel
I cannot make this program or any other version run. I always get a syntax error message. Has anyone experienced this and found a solution?
Thanks guys,
Ron
Make sure your calculator is in HEX mode, using decimal point for fraction mark, and see if it compiles.
(05-06-2014 06:13 PM)Han Wrote: [ -> ]Make sure your calculator is in HEX mode, using decimal point for fraction mark, and see if it compiles.
Hey Man, thanks for the answer. I made the program work on the virtual Calc. And I noticed that it was setup to HEX ( under shift*Home_setting) by default, and also the date format is different.
I assume that there is a problem with the format used to write the program and the format to read it ( they have to match)
So I changed my number to HEX , cannot find the decimal point fraction option, ? still not working.
Note: the program on the emulator is 51kb the program on the physical device is only 26kb when transferred.
any Ideas?
Thanks
(05-06-2014 06:35 PM)rontz111 Wrote: [ -> ]So I changed my number to HEX , cannot find the decimal point fraction option, ? still not working.
[Image: DecimalMark.png]
Thanks Joe, still no difference. Shows error on line 3.
Do you have yours working? can you post the code?
Thanks
(05-22-2014 01:04 PM)rontz111 Wrote: [ -> ]Thanks Joe, still no difference. Shows error on line 3.
Thanks
Yep, works fine. Here's the source code (I hope I didn't mangle it):
[attachment=683]
This application should natively be implemented in the firmware so pupils could use the periodic table with the exam mode activated.
What do you think ?
(05-23-2014 06:08 AM)Joe Horn Wrote: [ -> ]Yep, works fine. Here's the source code (I hope I didn't mangle it):
hi Joe,
wonderful!
but, what about Electronegativity function?
I get "H1 error..." under "Electronegativity function of Z"...
Is there a more recent version that correct that?
thank you
Salvo
I'll try to update if I have time.
(05-04-2015 06:51 AM)Mic Wrote: [ -> ]I'll try to update if I have time.
thanks a lot!
Smile
Salvo
Here is a new version based on the new firmware (7820 or higher).
Help is included in the ZIP.
Changelog :
- New applet launch with an icon.
- Automatic language detection (English and French).
- New electronegativity graph included.
- New toolbox key with 2 tools : Lewis representation and a picture of Mendeleiev.
[Image: HP_EL.png]
Download :
http://mic.nic.free.fr/hp/HP_ELEMENTS_3.zip
Have fun !
(05-18-2015 07:09 PM)Mic Wrote: [ -> ]Hi,
hi Mic,
thank you!
I'm trying it Smile
So we can delete the old program, now, and maintain only the App?
The electronegativity curve: is intended to show only if it's pressed the button or should it showing also without?
However now is indeed better!
Salvo
(05-18-2015 07:28 PM)salvomic Wrote: [ -> ][quote='Mic' pid='35446' dateline='1431976141']
Hello Mic,
thank you for this great program!
Transfer to the virtual prime works as written, but the program seems not to start (I've got a function app only). So i tried to "Check" the code of the program.
I had to add a line "HP_ELEMENTS();" as first line in the code, then "Check" printed "No errors in the program".
Don't know why this was neccesary, but now it's fine.
(05-18-2015 08:41 PM)Thomas_Sch Wrote: [ -> ]Transfer to the virtual prime works as written, but the program seems not to start (I've got a function app only). So i tried to "Check" the code of the program.
Did other users have this problem too ?
Maybe the source code should be changed accordingly.
(05-20-2015 11:08 AM)Thomas_Sch Wrote: [ -> ]
I've had the same problem, resolved the same way. I've also added a #pragma statement to make it compatible with different Digit Grouping options.
Here are the two lines I've added at the very beginning of the program:
#pragma mode( separator(.,;) integer(h32) )
HP_ELEMENTS();
Thank you. Code corrected.
@ Didier & Mic:
thanks for your testing and correction.
I tried to download the .txt, but on Android the text is read by HTML viewer, with nothing visible. If I try to open it with QuickOffice, the filename is visible but greyed out.
Pages: 1 2
