07-09-2018, 01:28 PM
All the HILBERT programs for the HP 48 series which I've seen, and the HILBERT function in the HP 49/50 series, use nested FOR loops to generate every element of a Hilbert matrix. This is slow and inefficient, since a much faster method exists which uses no nested loops.
Your Mini-Challenge, should you choose to accept it, is to write a better, faster HILBERT in User RPL. It should take any whole number n as its input and return an n×n Hilbert matrix much faster than the brute-force nested-loop method.
HP 49/50 users: Bonus points if your program returns a real matrix in approximate mode and a symbolic matrix in exact mode, as the HILBERT function does.
Reality check: The HP 50g's HILBERT function takes about 90 seconds to create a 50×50 Hilbert matrix of reals. A User-RPL HILBERT program can do the same job over 100 times faster (less than one second). My current attempt does so, and is 114.5 bytes long.
Disclaimer: This is a mini-challenge rather than simply an entry in the software library because nobody needs fast Hilbert matrices. Figuring out the faster method and then coding it up is presented here merely as a fun challenge.
