Full Version: 42 Complex Menu
I'm working on a very simple complex menu for the DM42/HP42 and would like some feedback, if anyone is willing.
The menu keys, similar to the suggestion found in another thread are:
i /_ ABS ARG Conj Cmplx
The idea is straightforward: hitting the i, changes display mode to rectangular, /_ changes to polar, ABS takes the magnitude, ARG takes the argument, Conj gives the complex conjugate, and Cmplx operates just like the COMPLEX key, to compose or decompose a complex number.
My current method of entry for say, 4 + i5 is:
4
i
5
Cmplx
Note that the menu keys are used and the result is that I see 4 + i5 displayed (automatically switching mode for verification).
The one function I'm really not sure about is the ARG. Everything else except Conj leaves the stack and LastX as is but I don't know of a built-in way to get the argument (like the ABS gets the magnitude but leaves the stack intact).
Any thoughts on this, on the layout, or other functions that might be useful? I've uploaded the program to my drive here:
https://drive.google.com/open?id=17tz7uN...7KKIwit3ua
How about:
00 { 25-Byte Prgm }
01▸LBL "ARG"
02 FS? 73
03 GTO 00
04 POLAR
05 COMPLEX
06 RECT
07 GTO 01
08▸LBL 00
09 COMPLEX
10▸LBL 01
11 X<>Y
12 R↓
13 END
It loses the contents of T but otherwise does the job. It could also be improved by checking that X is complex first.
Thanks Thomas.
Logan:
Maybe you want to consider in your menu This way to have 4 level complex stack.
Thank you, that's a nice program.
