Full Version: Color Demonstration
[Image: screen%2B2%2Bpentcolor.jpg]
[Image: screen%2B1%2Bpentcolor.jpg]
https://edspi31415.blogspot.com/2018/05/...ation.html
Introduction
The HP Prime program PENTCOLOR allows the cycler to through colors with the touch of the following buttons:
Key [ 1 ]: Red
Key [ 2 ]: Green
Key [ 3 ]: Blue
Each color setting cycles through the values of 0, 64, 128, 192, and 255. Exit the program with the Escape key ( [ Esc ] ). This program allows the user to cycle through different colors using RGB values.
I use two subroutines in PENTCOLOR. The first draws the text every time the key is selected, which allows for crisp text. The second is for value calculation. In subroutines on the HP Prime, all variables that are used must be local. Global variables are passed through the subroutine arguments.
HP Prime Program: PENTCOLOR
SBR1(); // sub routine text
// allows for crisp text
SBR2(); // sub routine calc
// saves space in main program
// main program
EXPORT PENTCOLOR()
// EWS 2018-05-07
LOCAL K,R,G,B;
// R,G,B are set at 0
RECT();
TEXTOUT_P("Ready! 1. Red,
2. Green, 3. Blue",0,20,4);
REPEAT
K:=GETKEY;
// Key 1, red
IF K==42 THEN
RECT();
R:=SBR2(R);
SBR1(R,G,B);
// Key 2, green
IF K==43 THEN
RECT();
G:=SBR2(G);
SBR1(R,G,B);
// Key 3, blue
IF K==44 THEN
RECT();
B:=SBR2(B);
SBR1(R,G,B);
UNTIL K==4; // ESC key
// sub routines
// all subroutines have
// all local variables
SBR1(x,y,z)
TEXTOUT_P("[ 1 ]: Red: "+x,
0,20,4,#FF0000h);
TEXTOUT_P("[ 2 ]: Green: "+y,
0,40,4,#00FF00h);
TEXTOUT_P("[ 3 ]: Blue: "+z,
0,60,4,#0000FFh);
TEXTOUT_P("[Esc]: Exit",
0,120,4);
// draw box
FILLPOLY_P({(160,20),(310,20),
(310,170),(160,170)},RGB(x,y,z));
SBR2(t)
t:=t+64;
IF t==256 THEN t:=255; END;
IF t==319 THEN t:=0; END;
RETURN t;
