04-01-2018, 04:36 PM
I haven't found this in .raw files anywhere else, so I'm offering it here.
This is an adaptation of David B. Wescott's Sunrise, Sunset, Twilight from 1900, published as HP User Library 00508C at hp41 . org.
The program requires 45 data registers, and there are a number of constants originally supplied on magnetic cards. I wrote a short program INITSUN that initializes the relevant data registers first (as if you'd loaded the data cards):
To use enter USER mode and:
1. Run INITSUN (loads registers with constants, only do once).
2. Run SUN
3. Optional: Enter Lat (+ N, - S), Lon (+ W, - E) and press B
4. Select precision desired by pressing E
5. Select double precision if latitude > 60 by pressing D
6a. Input date of desired times YYYY.MMDD; for standard times and press A.
6b. Input date of desired times YY.MMDDl; for Daylight Savings Time and press C
Optional: Review times by pressing A or C
For a new case: run at step 3.
You can delete INITSUN or copy it off to extended memory and remove it, as long as you preserve the contents of registers 22-42. Registers 43 and 44 are the default latitude and longitude; you might want to enter your latitude and longitude instead, letting you skip step (3).
(Edit) Posted SwissMicros DM41 dump files for INITSUN and SUN as a separate zip.
LBL "INITSUN"
9.936741207E-5
STO 26
4.908229466
STO 27
0.03000526417
STO 28
7.902463002E-6
STO 29
5.817764173E-8
STO 30
4.881627934
STO 31
628.331951
STO 32
5.279620987E-6
STO 33
0.4093197551
STO 34
-2.271109689E-4
STO 35
-2.860400719E-8
STO 36
8.775127628E-9
STO 37
0.01675104
STO 38
-418E-7
STO 39
-126E-9
STO 40
694023
STO 41
365.25
STO 42
37.106
STO 43
122.0879
STO 44
RTN
END
2. Run SUN
